UltraVNC 1.2.2.3 - Download links
Re: 1.2.2.3 pre-release
Fixed File Transfer of mapped network drives in r1176.
You can find the zipped exe (win7/10 x64) at http://www.resource-solutions.de/ultra/winvnc.zi_p for revision 1176.
Skyfighter, please test.
Opc Servers: http://www.wowbms.com/index.php/opc-servers
Wow Building & Energy Management System: http://www.wowbms.com/index.php
- 40
r1176-zip contains no viewer, only winvnc.exe - intended?Chrispy wrote:I did not change the viewer, it needs to be fixed too. Will get you a new viewer tomorrow.
r1176 winvnc.exe: behaves exactly as r1175
Skyfighter wrote:[...] receiving a folder from a network drive at remote machine does not work: nothing happens for approx. 80 seconds, then statusbar says "ERROR: File < X:\TEMP\FolderToTransfer > is not accessible on Remote Machine".
Yes, viewer was wrong, viewer is not running as service, so there is no impersonate from user.
hmm, could you give me a screenshot of what goes where, thanks?
OK, now I got it!
You can find the zipped exe (win7/10 x64) at http://www.resource-solutions.de/ultra/winvnc.zi_p for revision 1177.
- 40
Yes, that's it - you fixed the FileTransfer-Bug, Chrispy! Thank you very much!
But perhaps a few additional error-checks are useful:
I've tested different send/receives and they worked all, but one time uvnc tried to receive a folder (from network mapped drive @ remote machine) which should have a size of a few kb...FileTransfer started very slow and while asking myself what's going on I saw: it just had started to transfer a "!UVNC-....zip" with a size of ~2GB!
I canceled the transfer (the upper button did nothing...after ~30 secs I've pressed the second button: that killed the vnc session = viewer simple vanished...doesn't matter, just had to start a new session) and had a look at the %TEMP% folder of the remote machine: there were five or six "!UVNC-....zip" files with ~2GB size each. These zip files simply have the complete content of C:\Windows\System32\!
Tried to replicate that issue but had no success, yet. Maybe you have an idea where something could screw up and system32 gets zipped instead of the user-selected folder?
Fantastic, great to hear it works!
Yes, I will look. I think the zip files are done so the transfer is smaller, but not if the wrong files get zipped.
I had the issue with two monitors on the same vga card and ddengine enabled, now with 1177 rev works!!! thanks.
But if viewer click to switch main/secondary monitor then the conection has active but the displays is fully gray.
Ok, fixed in r1178
You can find the zipped exe (win7/10 x64) at http://www.resource-solutions.de/ultra/winvnc.zi_p for revision 1178.
Chrispy , r1178 build, VS2010 OS XP/WIN10 32/64
DOWNLOADS
https://www.uvnc.eu/download/1223/Ultra ... _Setup.exe
DOWNLOADS
@Lucent and Skyfighter, can you test with Rudi's build, thanks?
Hello Crispy, with your build rev 1178 works well but with the Rudi's build not work, the issue still here.
And I don't know why but with the crispy build connect very fast.
I noticed that the viewer with setting "Track remote cursor locally", the remote cursor has not the same coordinates with local, the remote cursor has x pixels on top of the local.
@Rudi, the date of the winvnc.exe in the zip is from 2018-10-31, it couldn't have had r1178.
@Lucent, please try the exe from the zip.
Now, works well. Thanks to both.
I did some more test:Lucent wrote:I noticed that the viewer with setting "Track remote cursor locally", the remote cursor has not the same coordinates with local, the remote cursor has x pixels on top of the local.
- W7 viewer one monitor, W10 dual monitor: OK
W7 viewer dual monitor, W10 dual monitor: Fails
W7 viewer dual monitor, w10 one monitor: OK
W10 viewer, w10 dual monitor: OK
W10 viewer, w10 one monitor: OK
@Lucent, maybe I missed it, but could you explain your scaling bug and how to reproduce it?
Viewer connect to a server with same or superior screen resolution, the window show the vertical and horitzontal scroll bars, then I select on viewer the option Display / Auto scale screen CTRL+ALT+F10.
The image scale correctly but the window no and appear black zones on windows's rigth side and at the window's bottom .
Ok, I can reproduce it. If you move any of the sides, after Auto size, then it shrinks to the correct size.
Yes.Chrispy wrote:Ok, I can reproduce it. If you move any of the sides, after Auto size, then it shrinks to the correct size.
auto size problem fixed in r1179
thanks @Chrispy,
I downloaded the file from http://www.resource-solutions.de/ultra/winvnc.zi_p but there is only winvnc.exe and not the viewer.exe.
Where can I download the rev 1179 version?
I have not uploaded a viewer, but I guess I can until Rudi has the chance to make a new official version.
File from http://www.resource-solutions.de/ultra/vncviewer.zi_p for r1179
Works perfect! thanks so much.
- 40
r1179: so far so good!
It doesn't bother me, but I found a way to reproduce the vanishing-cursor problem by using the switch-monitor-button (probably the state exists since r1174, not sure if i tested the switchmonitor-button after dualmonitor worked in r1174)
- after connecting and unlocking remote machine: all good, I see both monitors and cursor works on both monitors
- 1. switch-monitor button: only first (left) monitor -> OK incl. cursor
- 2. switch-monitor button: only second (right) monitor -> OK incl. cursor
- 3. switch-monitor button: dual monitor -> I see both monitors (OK), but while working on the second display (right half of the viewer-window) the remote cursor is only visible as long as I move my mouse, if I stop moving my mouse most of the time the cursor vanishes from the second display (right viewer half) and appears on the first display (left viewer half) [in approx. the same x/y-coordinate where the cursor should be on the second display].
Could you please describe your setup? Especially in terms of main monitor, second monitor positioning.
- 40
Win7 x64, 2x Dell U2311H connected to Intel HD Graphics 2500 (iGPU of Intel Core i5-3570), 2x 1920x1080
-> left monitor = main/primary
-> right monitor = second monitor
(only the first monitor shows the taskbar - I believe that's the default @ Win7?)
What else could be relevant?
Just to be sure: after connecting with vncviewer everything works as expected - only after using switch monitor button the cursor problem occurs if both monitors are shown. The switch monitor-button changes anything that breaks the cursor on the second display (if both monitors are shown).
- 40
further finding: using CTRL+ALT+DEL oder WIN+L (lock workstation) fixes the wrong cursor behaviour on second monitor!
I can confirm the same issue from Skyfighter.
