msrc4pluginkey Not Found [HELP]
Should you have problems with the DSM plugin? Here is the place to look for help or report issues
silver
Post by silver »
I have the last one RealVNC, I've try to use the MSRC4plugin.dsm, I've copyed the plugin on the same path where is WinVnc server and viewer but when i try to configure id i get this error:
Trying to find the key file:
Cheching for environment variable %msrc4pluginkey%
Not Found.
Looking for C:\Programmi\UltraVNC\rc4.key
KEY FILE FOUND.
Using key file.
Can help me?
mattice06082
200
200
Re: msrc4pluginkey Not Found [HELP]
Post by mattice06082 »
I'm not a DSM expert, but I believe that this is normal when using the NoReg version of the plugin. Is this the version that you are using?
Are you able to connect when using the plugin on both viewer and server despite this "error"?
silver
Post by silver »
thanks mattice for your repons.
I don't use the noreg version but i use MSRC4plugin.dsm, and i get this error only from client, on server is all ok.
mattice06082
200
200
You mention RealVNC in your post. Could the problem be related to a UltraVNC/RealVNC incompatibility? Is the plugin supposed to be compatible with both?
silver
Post by silver »
sorry, i use UltraVNC not RealVNC.
ollo
Post by ollo »
Well, what you got is no error. :)
As her says he's trying to find the keyfile, and he does that in various places!
1st try:
Not Found.
Using key file.
-> Ok, so there's no global variable named 'msrc4pluginkey' (holding the file path and name), and thus no key...
2nd try:
KEY FILE FOUND.
-> this time he looked in the UltraVNC directory, and whoops, there is the keyfile named 'rc4.key'.
So everything is ok, as long as the found key is the one you want. There are two other places UltraVNC is looking for it, but i don't remember.
