SC - What files to download? Site D/L is a mess
racassel
Post by racassel »
Which files do I donwload for the latest SC, that will work fast with Vista / Windows 7. I made my last build in 2005, and it works great except for Vista and 7. Looking around, there links to all kinds of files and no descriptions, and the links are broke. (Custom.Zip) for example.
What do I download to get setup? 1.0.9.1 ?????
RC23??? REL 1.0???? 2008 Update??
Where is Custom.Zip?????
If it is 2010, where do I upload it, to the 2008 Update portal?
Please advise. Thank you! And where do I make a donation?
Re: SC - What files to download? Site D/L is a mess
Server has been moved today... i'm still checking all links.
old server back online until new servers links and scripts are fixed
new
on
http://www.uvnc.com:8080/
racassel
Post by racassel »
Just my luck :-) .. After a while, it appeared to be working okay.
I must have had a mismush of dns's. Working good now in Orlando, FL!
Thanks! I was so confused, it looked like someone took a chainsaw to the site. Very good now!
Frykky
Post by Frykky »
Sorry but the latest release is RC23 or 1.00?
sfhub
Post by sfhub »
RC23 is actually 1.0.9.0 RC2.3 which led to 1.0.9.1
There might be some ctl-alt-del stuff for win7 still evolving on the RC2.3 thread.
For Vista/win7 you need to use (that's the latest version)
UltraVncSC update 2009 ( upload4.pl)
Frykky
Post by Frykky »
is a little bit confused isn't it?
racassel
Post by racassel »
Well, I just built 1.0.8.2. Should I patch that with the "Security Adviosry, then recreate the client side app?
Or
Should I run with the latest 1.0.9.1 or 109RC2? This is for production support of Internet clients.
Where do I make a donation?
We've been using this for years, and it's much better than paying the other guys 40-50-70 / month!
Suggestion:
A greatly needed feature is the option to install the program, and be able to reboot in safe mode and reconnect without customer intervention.
Ammyy.Com looks like they've customised a version of VNC that allows reconnecting with an installed viewer.
The viewer of 1.0.9.1 should be backwards compatible but i didn't made any tests yet with the older SC versions.
