Single click Multi instance problem
siva_vandanapu
Post by siva_vandanapu »
Hi
I have taken 2 different Single click exe's( both have different IP addresses in Helpdesk.text's). When i invoke both the exe's on a same server, i could see 2 remote sessions on different client machines.
But if i close one of the remote session on any one client machine, the other session is also ending.
Note:I observed that only one process is running in taskmanager of the server where both exe's are invoked though 2 remote sessions are established.
Can someone suggest how to close/end a particular/specific remote session only?
Thanks in advance
Siva kumar V
Re: Single click Multi instance problem
you should try update your Sc with 1.0.6.4 so you have 2 separate instance (but would be uncompatible with old OS win9x/Nt4)
not tested my self.
[topic=15865][/topic]
Only experienced user, not developer
siva_vandanapu
Hi Redge,
Where can I get the latest source code for 1.0.6.4 single click. I have downloaded SCII and tried working, which did not solve my problem.(2 instaces closing at a time on closing any one of the instance)
