with version 1.5.0.3 quick options selection is not saved, i.e. if I connect using modem setting, then close viewer and relaunch it, Auto is the default anyway, while with 1.0.3 the choice is remembered.
Ciao
Quick options settings not saved
Re: Quick options settings not saved
To keep the last connection setting, you need to check the box "Save connecting settings as default" (at the bottom positon of the vncviewer GUI).
You're right.
