2026-09-13: After more 5 000 000 (five million) views on forum for 1.8.x.x development versions...
A new stable version, UltraVNC 1.8.2.9 (2026-09-07) and 1.8.3.0 have been released: viewtopic.php?t=38204
SINGECLICK pre-test II
RudiDeVos
Post by RudiDeVos »
UltraVncSC.exe
Server installer
winvnc+hookdll+dsmplugin+key..all in 257k
The server connect to Localhost (testing)...
UltraVncSC_viewer_ecr.zip
dsmplugin + key
For encryption testing it has to be in the same directory as the viewer
Not a lot functional because the buildin localhost connection,
but the pupose is only to demonstrate how it will work.
The creator will auto create the UltraVncSC.exe based on ip
adresses and option you pass and allow to custom the logo.
eo
Post by eo »
This sounds exciting!
eo
Post by eo »
I think it would be handy to have an option on the systray menu for uninstall. Something more sophisticated, might be to have a viewer command that tells the server to uninstall too.
RudiDeVos
Post by RudiDeVos »
+Run in application mode
+All files are removed after run, no traces (even in registry)
Just quit application and auto cleanup.
On each connection you need to download the exe.
Current size 211k, with small icons/logo
The server file is bat generated allowing
rc4.key/logo.bmp/icon1.ico,icon2.ico/outgoing connection-list
being customized on the fly :)
lstargel
Post by lstargel »
Does this version support all of the Windows OS?
Plus how to you hard code what ip address and port you what it to connect? How do you change the logo? Why does it ask which helpdesk you want to connect to at the end of the install?
RudiDeVos
Post by RudiDeVos »
OS? All, distribution is done by web. Only hookdll, so all OS should be supported. Only encryption plugin can be a problem,
128bit is not supported on all platforms.
helpdesk? Your company has 4 helpdesk members, on startup
the user can select to correct member, by selecting the helpdesk members name, connection is made to his PC
Placed custom.zip in upload area.
Looking at the files i should be easy to see how customization is done.
If no logo, icon: default is used (custom logo need to have to same dimensions)
if no key, encryption is not possible
Default size is 210k, custom.zip size will be added to exe
Need to test my semi-auto creator....
The first 5 who mail me a Custom.zip will be answered by a
Custom UltraVncSC.exe.
Need to keep myself buzy until new java stuff is finished :)
helpdesk.txt (sample)
Helpdesk 1(encryp) -plugin -connect localhost:5500 -noregistry
Helpdesk 2 -connect localhost:5500 -noregistry
Helpdesk 3(recon) -autoreconnect -connect localhost:5500 -noregistry
First 19 chars (Visable in selector)
command line start at possition 20
(new) -plugin --> use encryption
lstargel
Post by lstargel »
Rudi what is your emial address? all i can do is PM on the board. what info needs to be in the custom.zip file? How would i go about changing the info like the logo and the ip address that it would connect back to? If i need the source files where can i get those?
Sergio
Post by Sergio »
Rudi:
I e-mail you the custom.zip at your sourceforge e-mail. I hope being among the first 5 ! :)
EDIT
Uups ! Sourceforge returned the mail: "For the time being, we are blocking all mail with the .zip extension"
Sergio
Post by Sergio »
Rudi:
I tested the UltraVncSC.exe you send me. Works like a charm ! ... and in only 200 kb ...
I get a quick and encrypted reverse connection with a single click ! (to be honest, with a double-click :wink: )
Beautifull job !!! :D
Some feedback: the -autoreconnect parameter is not working, at least for me ...
nu2bart
Where can I download this UltraVncSC.exe?
Post by nu2bart »
Hi all,
I'm looking for this "UltraVncSC.exe"
I searched this forum and looked on http://dl.ultravnc.net cannot find it.
Any pointers?
Regards,
Bart.
- BartPE, admin's best friend -
nu2bart
Post by nu2bart »
Alex
Ultra VNC SC
Post by Alex »
You can find it at http://www.uvnc.com, there are user manual too..........
