auto reconnect to repeator
Simple, Free, Open Source UltraVNC Wrapper Supporting Windows and Mac OSX
cabria
Post by cabria »
I have several computers running with chunkvnc and it works really well :thumbs: . but since several of these machines run continuously.
then chunkvnc does not restore the connection to the repeater if the repeater is rebooted. is there that the way to make the host auto connnect agian?
supercoe
400
400
Re: auto reconnect to repeator
Post by supercoe »
It should reconnect to the repeater if the connection fails.
Keep in mind that leaving InstantSupport installed as a service for an extended period of time (over a day) some users have had issues with it reconnecting.
It's not recommended to leave it installed as a service for an extended period of time currently.
I believe Rudi fixed this issue with the newer releases of the UltraVNC server, you may want to try compiling InstantSupport with a newer winvnc.exe file in the SRC\InstantSupport_files directory.
Sorry that this bug exists, it will be addressed in the next release.
http://www.chunkvnc.com - ChunkVNC - Free PC Remote control with the Open Source UltraVNC wrapper InstantSupport!
cabria
Post by cabria »
After compiling chunkvnc with with version 1.1.9.0 it works perfectly.
The host resumes contact to the repeator without a problem.
And now it is also possible to send CAD to the server too.
:thumbs: :thumbs: :thumbs: :thumbs: :thumbs: :thumbs:
supercoe
400
400
Post by supercoe »
Very good! Thanks for the info. :)
