Feedback 1.1.0.0
Feedback 1.1.0.0
Please add feedback here
Re: Feedback 1.1.0.0
I installed the 1.1 x64 version but was not able to install the driver.
Winvnc states driver is not installed.
Don't see anything in the event log...
I tried setupdrv.exe with admin priv and selected run as admin.
Any suggestions?
Thanks in advance
Config: Win7 Ultimate SP!
Any suggestions?
Thanks in advance
manual installation
cmd "run as admin"
setupdrv.exe install
I will check the addon installer again..
cmd "run as admin"
Addon install fine on win7 w32. i will test x64 later..
How was it installed ? Console, RDP ?
Video driver installation from TSC is not supported by MS.
hello,
UltraVNC_1.1.0_xp_Setup.exe says that it requires Windows NT 6.0.6000 or later, windows xp is version 5.1
-lysmy
-lysmy
SO,minversion is set wrong for xp_setup ....
Thanks, i will check this
ONLY 2 reactions....and Server is pumping more then 100 downloads/hour.
I just hope it's because nobody has serious issue's
xp setup corrected and reuploaded.
minversion was wrong..
Alt+Tab isn't working for me.
Viewer is running on Windows 7 Ultimate 32bit and server is running on Windows 8 Enterprise 32bit.
Thanks for the feedback..
I could repeat it.
works on win7, fail on win8.
Looks like the OS is blocking it, seems to be a part of the win8 protection to avoid
that people remove the initial desktop ....!ç"è'ç!&è'ç!"è&çà'"
Why the hell can't we open win8 the way we want... without a touch screen the current interface
doesn't offer me anything extra.
I could repeat it.
Ctrl+Alt+F4 (and the send-to-host-button) isn't working, too. Ctrl+Shift+Esc on the other hand works as expected.
Well, I'm just testing Windows 8 - and I don't know by now, what i should think about it. It's really fast, and with your system hook dll ultravnc is although real fast without the need of the driver.
But: what should I do with metro - sorry: modern ui - on a mouse-/keyboard-based pc with big monitor?
I have to correct my priop posting. The send-to-button does work, but the window opened in background - so I didn't saw it when I tested it.
xp installer works now, thanks for quick update.
noticed that if you install it as service which is started, it gives error when trying to add groups to "new ms logon", solution is stop service and then add groups.
about vncviewer.exe: did some tests and noticed that "-proxy server:port" option doesn't work properly, it reads server name but ignores port number completely, tries always to connect to port 5900.
this is what i try to test:
"vncviewer.exe -proxy server:5901 -connect workstation:5900"
from netstat:
TCP xx.xx.67.136:49599 xxxxxxx:5900 SYN_SENT
so it bang it's head to firewall.
-jml
from netstat:
-jml
setcad.exe
Hi.
What is the point of the setcad.exe?
I looked at the source code and found that the body of _tmain is empty so the function Enable_softwareCAD() which is defined in setcad.cpp is not beeing called at all.
Or did I miss anything obvious?
Cheers
Cheers
LOL, indeed it seems that it doesn't do anything.
It should change the registry to allow softwarecad.
Hi
I'm having a similar problem with the xp addons file as was initially had with the setup file it also says
This program cannot be installed on Windows NT version 5.1.2600 or later.
Chade
Chade
"vncviewer.exe -proxy server:5901 -connect workstation:5900" doesn't work butlysmy wrote: about vncviewer.exe: did some tests and noticed that "-proxy server:port" option doesn't work properly, it reads server name but ignores port number completely, tries always to connect to port 5900.
"vncviewer.exe -proxy server:5901 workstation:5900" works fine
part from http://www.uvnc.com/docs/uvnc-viewer.html documentation:
---clip---
"%:\programfiles%\UltraVNC\vncviewer.exe" -proxy host:5901 -connect hostname
"%programfiles%\UltraVNC\vncviewer.exe" -proxy distributor:5901 -connect host -dsmplugin filename.dsm
---clip---
maybe a small bug in somewhere in code or documentation
and yes, xp addons cannot be installe nt 5.1 or later, wrong max version?
testing new viewer and server:
i have this issue:
connect viewer and server to repeater using SecureVNCPlugin.dsm, viewer use many cpu and lock on "request password" screen
using viewer 1.9.6.2 and new server 1.1 i can input password but viewer close.
using new viewer 1.1 and server 1.9.6.2 i have a warning message (password can be haked) but it works good.
all test are been done with winvnc.exe 32bit (UltraVnc_bin.zip), on windows xp and windows7 32 and windows 7(64)
without securevncplugin.dsm it works good.
regard
Sainsuper
i have this issue:
regard
Sainsuper
Thanks this limit the search to the server part with plugin.
Installed on a Windows 7 Pro 64bit machine (will be used as the client). Installed on a Server 2008 R2 Enterprise system (will be used as the server). I notice on both that after the install I had both the old version and the new version on the machine, with the old version running. I had to uninstall the old version and reinstall the new one to get it running and reporting the correct version number. I hope that will be more automatic when the new version is released...
On the server machine I launched the "Edit Settings" application and setup the correct passwords. When I attempted to connect from the client the password wasn't accepted. I went to the server machine and used the popup menu on the running server icon at lower right to bring up the admin properties. Changing the password there allowed the change to work. Any chance Edit Settings only edits the background database and the server is never told of the changes?
I really like the much snappier screen response!
"Edit Settings" application it's just a ultravnc.ini editor.
Permissions are taken from the desktop user.
Using the editor, winvnc doesn't know options changed.
Changes take effect next time winvnc is restarted.
SecureVNCPlugin with New MS Logon doesn't work. Viewer asks only for the password (instead of username/password combo) and things go haywire from there...
It does work if vnc password is configured on the server side instead of new ms logon.
Setup: Win7 x64 on both sides.
Cannot configure groups for the old ms logon. I can check it in the server settings editor. But as soon as I click "Configure MS Logon Groups" button I get a crash in uvnc_set:
Problem signature:
Problem Event Name: APPCRASH
Application Name: uvnc_settings.exe
Application Version: 1.0.0.1
Application Timestamp: 504f8033
Fault Module Name: uvnc_settings.exe
Fault Module Version: 1.0.0.1
Fault Module Timestamp: 504f8033
Exception Code: c0000005
Exception Offset: 000000000002956c
OS Version: 6.1.7601.2.1.0.256.48
Setup: Win7 x64
Problem signature:
Setup: Win7 x64
I thought this would mean the Fullscreen VNC window would stop bleeding a black line a few pixels into my right monitor, but I was wrong.-better multi monitor support
Is this at all fixable?
Using AMD cards
1. Landscape 1920x1080 (centre)
2. Flipped Portrait 1080x1920 (to the right of #1)
Problem with installing the Addons
XP 32 Version 5.1(Build 2600.xpsp_sp3_gdr.120821-1629 : Service Pack 3)
Getting the Message:
This Program can not be installed under Windows NT Version 5.1.2600 or higher
(Dieses Programm kann nicht unter Windows NT Version 5.1.2600 oder höher installiert werden.)
I'm trying to install UltraVNC_1.1.0_xp_Addons.exe and getting the above message. I need the DSM Plugin urgently vor my viewer because I'd installed unfortunally a server with the plugin activated and a passphrase.
thankful for any help
Regards
bejay
Regards
bejay
you always can download the bin.zip.
and copy the plugin in the vnc folder.
- 20
Please add this options to version 1.1
1. Check folder permission where uvc_service is installed . example if folder don't have permissions for SYSTEM account , now UltraVNC givs Failed: Permission denied but without any other info where is the problem .
2. Add option install as service with not default service name ( example for two instances ) example winvnc.exe -install -name=uvcs_service2
3. Add option run program after successful login on the server siede exaple in ultravnc.ini like RunProgram=C:\test.exe
1. Folder needs to be a secure folder ( program files /system32) else certain functions will not work.
This folders always have system account access.
2. Start/stop/install/uninstall service depend on the service name. Using a special service name require to save the service name in ultravnc.ini.
But then your second instance will also use that name.
We use shared memory between service/desktop part. If you run 2 instances then both wil use the same memory...this is unpredictable and
possible crash winvnc...
3. The program wil run as "system" on the logon desktop this is invisable.
What are you actual trying to do !
- 20
Example I deliver IT support for new company , but this company has two IT support partners - me and another company and this company have own UltraVNC instance ... I can uninstall and install my own UVNC installation / or change password. I would like to avoid that situation.Rudi De Vos wrote:1. Folder needs to be a secure folder ( program files /system32) else certain functions will not work.
- 20
Ok but run . Example I can writte program to kill windows media player process when i connect via UltravncThe program wil run as "system" on the logon desktop this is invisable.
