update old sc (online creator) update 27/08
Re: update old sc (online creator) update 27/08
Just tried it and it works great! However I notice that when you exit the program, the user gets a "This program might not have installed Correctly" pop up. Is there any way to get rid of this from popping up every time you close the vnc session?
Rudi De Vos wrote:SC or ultravnc 1064 with option -sc_XXX require the ultravnc viewer and is not compatible with all existing viewers.
To indicate that the viewer need to accept the server and show some server info before the connection is made we use a non official pseudo protocol 3.16. Only the ultravnc viewer understand this and has the needed code to show this accept box.
Hi there, is this what is keeping me from using UVNC SC on the windows side and Remmina on a linux machine? If so, is there any possible way to get the two working together?
Hi there,
I keep trying the uploader at http://support1.uvnc.com/cgi-bin/upload4.pl but it doesn't seem to be using my custom.zip. I appear to be getting someone else's executable.
Does this uploader still work?
Try the ones on the SC downloads page at http://www.uvnc.com/downloads/single-cl ... loads.html
Hello there.
I am now making the switch from an earlier windows XP implementation to a windows 7, and have finally taken the inevitable. I would have to say that the upgrade in straight-line connection speed is just nice and what a big improvement at that.
I am looking at some issues though with portability of the Custom.zip file to be accessible on the windows 7.
