Mouse problem on application bar of windows 7/64bit
Anakin
Post by Anakin »
I have a problem with the right click of the mouse on windows 7 application bar : the click simply doesn't work...
I try with/without aero...
Any suggestion?
Thank you
Re: Mouse problem on application bar of windows 7/64bit
unrelated to ultravnc
check the mouse setting(hardware and sound) on control panel of remote computer
or/and
control panel... Easy of Access center (change how mouse works)
Only experienced user, [u]not[/u] developer
Anakin
Post by Anakin »
redge wrote:unrelated to ultravnc
or/and
I don't agree : it works perfectly even with other remote control (teamvi**er), and obviously in normally use of windows...
It happen in 3 different windows 7 with ultravnc...
Only taskbar or also with other applications ?
Do you have an " elevated" window open ? ( started via uac)
Is winvnc running as service or applications ?
When winvnc is running as application is it started as admin or with
"runas admin" ?
Anakin
Post by Anakin »
Rudi De Vos wrote:Only taskbar or also with other applications ?
With a desktop icon is all ok. I click with the right mouse and I see the menù correctly.
I discover the problem with the bar is not that the click doesn't work : the problem is that from remote you don't see the menù open (but if you look at the original monitor the menù is open : I've try with a notebook looking the original...).
Rudi De Vos wrote:Do you have an "elevated" window open ? (started via uac)
Probably is my bad english but I don't understand the question : UAC is disabled.
Rudi De Vos wrote: Is winvnc running as service or applications ?
"runas admin" ?
Uvnc is running as an automatic service.
Try
Enable alpha blending capture (server options)
If you are not using aero, semi transparent windows require this special
capture mode.
Anakin
Post by Anakin »
This are my settings of uvnc :
..and this is my bar when my mouse stop on a task...
I've installed on my pc a program that change start menu to classic XP style.
The program is call Classic Start Menù (but it doesn't change anything in the bar apparently..).
Try with
[v] Capture Alpha-blending
Anakin
Post by Anakin »
Rudi De Vos wrote:Try with
SOLVED!!!!
:D :D :D :D
Many thanks!!!
