request: ding on chat
Any features you would like to see in UltraVNC? Propose it here
ToddAndMargo
Post by ToddAndMargo »
Hi All,
When I am doing a support session, the users ignore me totally, until I call them on the phone. When I open a chat session, they never respond. (I have tried typing in "Free Food" and "Free Beer". Neither work.)
Would you please consider a "Ding" sound at the other end when I open a chat session. If the user does not respond, a "dinger" button would also be useful.
Many thanks,
-T
JDaus
Friend of UVNC
Friend of UVNC
Re: request: ding on chat
Post by JDaus »
ToddAndMargo wrote:Would you please consider a "Ding" sound at the other end when I open a chat session. If the user does not respond, a "dinger" button would also be useful.
yep, I agree with this one ... I can do it in autoit ... so i am guessing it can't be too hard :-P
SecureTech.com.au
On open added...
No button, this is a lof of code and extra message between viewer and server is not possible ( break compatibiliry with older version)
If no respons, just reopen chat window to ding-dong again...
http://www.uvnc.eu/download/winvnc_32_ding_dong.zip
This was the last request for 1057
We need to release 1057 and we can keep changing and adding thing until 2010 :)
Is 1057 stable enough for next release ?
JDaus
Friend of UVNC
Friend of UVNC
Post by JDaus »
fair enough rudi ... didn't think about backward compatability ... thanks for adding the ding :)
will test out the latest version ...
SecureTech.com.au
aromo
Post by aromo »
Is there a way to disable the Ding Dong function?
I give support to radio stations, and it's not a good thing to play sounds in their computers.
pgmoney
100
100
Post by pgmoney »
aromo wrote:Is there a way to disable the Ding Dong function?
Would this work for you?
If the ding_dong.wav file exists in the current folder it plays. if you delete the file it's silent or you can change the wave to what you like.
Code changes below...
TextChat.cpp
#include <Mmsystem.h>
BOOL PlayResource(LPSTR lpName)
//PGM     BOOL bRtn;
//PGM     LPSTR lpRes;
//PGM     HANDLE hRes;
//PGM     HRSRC hResInfo;
//PGM
//PGM     /* Find the WAVE resource. */
//PGM     hResInfo= FindResource(hAppInstance,MAKEINTRESOURCE(IDR_WAVE1),"WAVE");
//PGM     if(hResInfo == NULL)
//PGM        return FALSE;
//PGM     /* Load the WAVE resource. */
//PGM
//PGM     hRes = LoadResource(hAppInstance,hResInfo);
//PGM     if (hRes == NULL)
//PGM       return FALSE;
//PGM
//PGM     /* Lock the WAVE resource and play it. */
//PGM     lpRes=(LPSTR)LockResource(hRes);
//PGM     if(lpRes==NULL)
//PGM       return FALSE;
//PGM
//PGM     bRtn = sndPlaySound(lpRes, SND_MEMORY | SND_SYNC);
//PGM     if(bRtn == NULL)
//PGM       return FALSE;
//PGM
//PGM     /* Free the WAVE resource and return success or failure. */
//PGM     FreeResource(hRes);
//PGM     return TRUE;
	char szWavFile[MAX_PATH]; //PGM
	if (GetModuleFileName(NULL, szWavFile, MAX_PATH)) //PGM
	{ // PGM
		char* p = strrchr(szWavFile, '\\'); //PGM
		*p = '\0'; //PGM
		strcat(szWavFile,"\"); //PGM
	} //PGM
	strcat(szWavFile,"ding_dong.wav"); //PGM
	if(::PlaySound(szWavFile, NULL, SND_APPLICATION | SND_FILENAME | SND_ASYNC | SND_NOWAIT)!= ERROR_SUCCESS) //PGM
		return FALSE; //PGM
	else //PGM
		return TRUE; //PGM
WinVnc.rc
// WAVE
//PGM IDR_WAVE1               WAVE                    "res\\ding_dong.wav"
#endif    // Dutch (Netherlands) resources
JDaus
Friend of UVNC
Friend of UVNC
Post by JDaus »
pgmoney wrote:If the ding_dong.wav file exists in the current folder it plays. if you delete the file it's silent or you can change the wave to what you like.
nice one PGM ... this should be the norm IMHO...
a way round it sounding (without having to compile sources ...) is to fire-up reshacker and delete the wav from the resources, and that will stop it ...
but make sure you test thouroughly before supplying to customers, as it may error if file cannot be found ...
SecureTech.com.au
