Two Questions:
Did MS-Logon II get implemented in the java viewer?
Is this accurate?
• MS-Logon 1 uses the RFB version string to communicate it's desire to use a different authentication technique. If the version is 003.004 the Security Negotiation requests that it use VNCAuthentication and does a hybrid of VncAuthentication (DES encrypted with the fixed key) and MS Challenge.
• MS-Logon II uses the Security Negotiation protocol (sending "-6") to select the authentication procedure which is the MS Challenge.
Trying to understand ms-logon
'Tis fun to learn, 'Tis funner to teach
thetechnologyteacher.wordpress.com
Re: Trying to understand ms-logon
Marscha, could answer but we don't have any news from her since 1 year ago.
Here is something for you
MS-Logon procedure.source detail
http://code.google.com/p/vncthumbnailvi ... etail?r=16
