2026-03-11: CVE-2026-3787 Clarification: https://forum.uvnc.com/viewtopic.php?t=38155
Problem with Icons :(
erkdog
Post by erkdog »
I'm having problems with the icons on the EXE the SC generator is kicking back to me.
I have created the appropriate 32 x 32 w/ 32 bit depth icons, but when I upload the zip, it throws back the file with the default icons instead!!!
Any help would be greatly appreciated.
My file is located at:
http://ecansol.com/Reverse-VNC1.zip
Re: Problem with Icons :(
use offline creator
[topic=7991][/topic]
Only experienced user, not developer
erkdog
Post by erkdog »
So Images on the online creator are just hit and miss?
erkdog
Post by erkdog »
Offline Creator does not work either.
Is there something wrong with the images I have in that zip file?!?
erkdog
Post by erkdog »
you need to use same name and extension for the icon as the original you want to replace
other solution
resource hacker
http://angusj.com/resourcehacker/
erkdog
Post by erkdog »
I did use the same name and extention!!
icon1.ico
icon2.ico
And I even browsed and everything in the offline creator, and it no worky!!
