Remote Support
jonathanb
Remote Support
Post by jonathanb »
I am looking at offering remote support to clients and I was on the lookout for some software like webex(not that I like it). I want the functionality to be able to conect there machines even if their behind a firewall. I looked at PcHelpWare and was really interested in the software as it seems it will do everything I want.
The main problem I have is the I want to be able to install the server on people machines and enable the to be able hide it. Maybe as a service or something like that. Is that possible.
As a feature suggestion would be nice if you can create servers that would connect to a website and update the webby to say they are loged on and able to connect to. Then you just click on that person and it fires up you client and it connects.
Thanks for you help in advanced.
bevtech
Re: Remote Support
Post by bevtech »
it is good thought has been suggested before but mostly likely pchelpware as a service might not happen?? Maybe somethings will change in version 2 but not sure utlravnc needs to be completed first..:)
Windows XP Home, Pro SP2, Windows 2003 SBS server SP2 (EN), Windows Media Center Editon 2005, Windows Vista Home Premium, Fedora Core 6, Windows 9X, PcHelpWare 1.0, UltraVNC 1.0.8.2
User not developer ;)
jonathanb
Re: Remote Support
Post by jonathanb »
ohh ok no prob
thor918
Re: Remote Support
Post by thor918 »
what you need is logmein.com
it does that. it installes as a service, it has a webpage where you can see who is online, and they have free accounts, with limited features.
jonathanb
Re: Remote Support
Post by jonathanb »
yes something like that. I am customising PCHelpWare my self now so it should do almost the same job now.
thor918
Re: Remote Support
Post by thor918 »
if you figure out something new.. please post your results.
it may contribute to the community here.
jonathanb
Re: Remote Support
Post by jonathanb »
Well I can't program so I can't really do more than what is already listed in the help. I am just going to setup my own repeater and stuff.
bevtech
Re: Remote Support
Post by bevtech »
The standard repeater instructions will work for pchelpware it just has some more added features
can use 3 ports instead of 2
Tip: Do not mess with the dynalias ports or options they are extremely buggy and i would restart your repeater daily ..:)
