Hi all,
I'm new to this uvnc and i cant get it working correctly.
When i open the file combiled in this web and click to connect the "server" computer it ask on the server computer "do you allow or reject the connection" , after I allow it the screen on the "viewer" computer goes black for a second and then the combiled program closes itself. I have no idea what could be the problem, maybe you guys can help me out here.
Thanks in advance,
Marek Rattiste
Oh and here's my helpdesk.txt:
[syntax="text"]
[TITLE]
Xadventure kaughooldus
[HOST]
Marek Rattiste @ home
-connect 213.168.29.94:5500 -noregistry
[HOST]
Marek Rattiste @ dyn
-connect 192.168.0.230:5500 -noregistry
[TEXTTOP]
Tee topeltklikk nimel, et avada ühendus!
[TEXTMIDDLE]
Enne ühenduse avamist helista
[TEXTBOTTOM]
56618001 - Marek Rattiste
[TEXTRBOTTOM]
[TEXTRMIDDLE]
[TEXTRTOP]
[TEXTBUTTON]
Rohkem infot
[WEBPAGE]
http://www.xadventure.ee
[TEXTCLOSEBUTTON]
SULGE
[BALLOON1TITLE]
Ühendan ...
[BALLOON1A]
5 min try period
[BALLOON1B]
Kui ebaõnnestub siis programm sulgub automaatselt
[BALLOON1C]
from your system.
[BALLOON2TITLE]
Ühendus aktiivne.
[BALLOON2A]
Teie desktop on nüüd nähtav!
[BALLOON2B]
Ühenduse saab nupuga "close"
[BALLOON2C]
sulgeda
[WEBPAGE]
[/syntax]
[mod=3406,1162388474] moved to single click subfourm .. [/mod]
[mod=494,1162513097]replaced code by syntax=text[/mod]
Connection fails after the background goes black
Re: Connection fails after the background goes black
The error log shows me this:
Still counting on you guys
Wed Nov 01 11:36:11 2006
Marek Ra --The operation completed successfully.
Wed Nov 01 11:36:19 2006
S:\UltraVNC\winvnc\winvnc\vncserver.cpp : KillAuthClients() done
S:\UltraVNC\winvnc\winvnc\vncmenu.cpp : quitting from WM_DESTROY
--The handle is invalid.
S:\UltraVNC\winvnc\winvnc\winvnc.cpp : shutting down server
S:\UltraVNC\winvnc\winvnc\vncserver.cpp : shutting down server object
--Attempt to release mutex not owned by caller.
S:\UltraVNC\winvnc\winvnc\vsocket.cpp : shutdown socket
S:\UltraVNC\winvnc\winvnc\vsocket.cpp : closing socket
S:\UltraVNC\winvnc\winvnc\vncsockconnect.cpp : quitting socket connection thread
--A request to send or receive data was disallowed because the socket is not connected and (when sending on a datagram socket using a sendto call) no address was supplied.
S:\UltraVNC\winvnc\winvnc\vncserver.cpp : KillUnauthClients() done
--The operation completed successfully.Still counting on you guys
hmm... does your vncviewer work when you connect to a local server in you lan???
What options did you change from the default??
Do you have the ports open in your firewall for uvnc to communicate..?
Windows XP Home, Pro SP2, Windows 2003 SBS server SP2 (EN), Windows Media Center Editon 2005, Windows Vista Home Premium, Fedora Core 6, Windows 9X, PcHelpWare 1.0, UltraVNC 1.0.8.2
User not developer ;)
First of all thank you very much for answering!bevtech wrote:hmm... does your vncviewer work when you connect to a local server in you lan???
1.No it doesnt even work in lan
2.I've tried basicly all different options, none of the combinations seems to work...
3. Yes I opened the right port.
Thanks again
PS: If you have msn or something similiar maybe we can communicate there ?
If it doesnt work in a LAN how do you expect it to work in a WAN??
you have to get a successful testing in LAN without encyption before you try a wan connection.
Once successfult lan testing then if you are going to use encyption then implement it then make sure it works in LAN competely before working in WAN..
Then try Single Click..
