Msi Installer(With driver) or script for network deployment
cheesegoduk
Post by cheesegoduk »
Has anyone managed to create a customiseable MSI install with the ultravnc speedup driver or a bootup script for windows that will do the same thing?
I'd like to be able to deploy ultravnc across the network without having to visit each machine (200+ :x )
Cheesegoduk
joefu
Script
Post by joefu »
I don't have a MSI script however I do have a autoit script if your interested in. This script has all files needed for UltraVNC and creates all registry keys needed for UltraVNC and puts it all into a EXE file. You can even make autoit create all shortcuts if you like.
joefu
Post by joefu »
I don't mind. What is your email address?
nobody481
GenControl
Post by nobody481 »
I think something that you all might want to know about is a program called GenControl. You don't have to install anything on the remote computer to connect to it. If the username you are logged in as is an administrator of the remote machine, then GenControl will copy VNC to the remote machine, start the service, and connect you to it. You can get it from http://www.gensortium.com/products/gencontrol.html
UltraSam
Post by UltraSam »
GenControl is cool when you work over the same domain/VPN :)
It would be easy to replace their current tightVNC viewer and server in their source code with the Ultra ones (+ DSM plugin).
Under investigation...
UltraSam
orphic
Re: GenControl
Post by orphic »
nobody481 wrote:I think something that you all might want to know about is a program called GenControl. You don't have to install anything on the remote computer to connect to it. If the username you are logged in as is an administrator of the remote machine, then GenControl will copy VNC to the remote machine, start the service, and connect you to it. You can get it from http://www.gensortium.com/products/gencontrol.html
Cool, but can it be adapted to install UltraVNC?
joefu
Autoit
Post by joefu »
Any body who want to try using autoit here is a website you can download the script.
[url]http://kezmega.50megs.com/[/url]
Good luck. If you have any question just email me.
sbostedor
100
100
Post by sbostedor »
If you'd like me to host it for you, I will. Send an email to sbostedor@vncscan.com. Sending to everyone like this has to be a drag!
Steve Bostedor
http://www.vncscan.com
Super Simple UltraVNC Management
bobbo
Post by bobbo »
I found out someone is already hosting it.. It is located.
scovel
100
100
Post by scovel »
Did anybody look at FastPush? Again, if you are in a domain and have admin rights, it will push it out to the machines for you.
http://www.darkage.co.uk/
I've used it many times. Nice script. You can modify it to meet your needs too.
Sean
sbostedor
100
100
Post by sbostedor »
Yes, VNCScan ( http://www.vncscan.com ) uses FastPush to push UltraVNC out to remote computers. You can even pass it alternate username/password and set up deployment profiles for different VNC deployment scenarios.
VNCScan is the only program that I know of that can push UltraVNC out to a network with MS Authentication enabled and configured.
Steve Bostedor
bobbo
any luck
Post by bobbo »
Has anyone use the autoit script to push out UltraVNC?
sbostedor
100
100
Post by sbostedor »
I downloaded it. It looks like a reinvention of the wheel, really. The fastpush script already does what this new script is trying to do and it does an excellent job. Why do we need another push script when Richards works just fine?
If you want a push script and don't need all of the features of VNCScan, you can simply download the free script at :
http://www.darkage.co.uk/downloads/
Steve Bostedor
TechFan
Former moderator
Former moderator
Post by TechFan »
Still no REAL msi available? It sure would be great to distribute in the same way as other packages on the network.
sbostedor
100
100
Post by sbostedor »
I think that the difficult thing about installing remotely via MSI is tying in all of the custom settings. If you simply wanted an MSI an no script at all, you'd have to compile your custom VNC settings with that MSI somehow.
I guess that in order to better answer that question, we'd have to know exactly how you wish to deploy UltraVNC. How do you plan on getting this MSI to execute on the remote computers? Is it with Active Directory? If so, now do you plan on setting your custom VNC password on the remote computer and setting the other settings after the MSI has been ran?
If you answer at all involves a script then my last question would be "why not just do it all with the script?" I've made an MSI before using RapidDeploy by Altiris but I didn't see the benefit because in the end, I went right back to scripting to get the settings applied. It turned out to be a big waste of time.
Steve Bostedor
TechFan
Former moderator
Former moderator
Post by TechFan »
Well, all my installs should be exactly the same, so I was just hoping to have a simple package with all those settings already. . .but maybe it isn't possible. . .I am not a MSI expert for sure. . .
sbostedor
100
100
Post by sbostedor »
Have you checked out http://www.softpedia.com/get/Authoring- ... EMSI.shtml
I've not tried it, I just saw it in a google for "freeware create MSI"
Steve Bostedor
TechFan
Former moderator
Former moderator
Post by TechFan »
I have seen it. . .just haven't had a chance to really dive into it yet. . .just about to deploy updated UVNC to all workstations. . .so now hoping to find a good solution soon. . .
scovel
100
100
Post by scovel »
What's an MSI worth to ya? :wink:
TechFan
Former moderator
Former moderator
Post by TechFan »
That depends on how much it will cost me. :-) If I can roll it out and create updated versions myself, it could be quite valuable. . .but I am using vnc. . .so that would reflect somewhat on my ability to pay for remote control. . .;-)
Of course if one of these vnc management shops gets it in for uvnc that would be added value for them.
scovel
100
100
Post by scovel »
I guess the next question is: do you have any development tools available. Modifying an MSI is going to require some development tools. If I were to make an MSI I'd use Visual Studio .NET 2003. You'd need the same tools to modify it.
Sean
Email me and we'll discuss your requirements.
TechFan
Former moderator
Former moderator
Post by TechFan »
sent email
sbostedor
100
100
Post by sbostedor »
I would be willing to create an MSI deployment at no cost. It really shouldn't be that hard. Where would you like to begin? Should we start a new thread?
How about if we begin with a question. What makes an MSI more valuable than a script deployment?
Steve Bostedor
TechFan
Former moderator
Former moderator
Post by TechFan »
The scripted version requires me to use yet another scripting syntax and make sure the interpreter is working on all machines. With a MSI, I can just publish it along with the other MSI packages I already deploy with a GPO via Active directory and force the software to install on the computer's system account's security level.
sbostedor
100
100
Post by sbostedor »
VNCScan already has a scripted way of remotely deploying UltraVNC. We're talking about an MSI, now.
So, you want an MSI with all of your settings predefined already? How do you plan on keeping it up to date when you want to use a different password or you decide that you want to use a different encoding?
This is the most major roadblock for a monolithic MSI file that deploys VNC and then also is responsible for your custom settings.
Would it be acceptable to be able to deploy a silent install of the files and basic default settings and then your custom settings are applied afterwards via login script or group policy?
Steve Bostedor
TechFan
Former moderator
Former moderator
Post by TechFan »
Yes, I would like to configure all my settings for the MSI. I do not intend to change them very often. I use MSLogonII and have a set domain group that has access and the plugin is configured with one key for general use. Also, with MSI's I can apply new settings/update files by deploying the MSI again. I would be willing to change some settings with GPO, but all setup should be done in the MSI.
sbostedor
100
100
Post by sbostedor »
It can also push install UltraVNC to computers with the DSM plug-in configured and working. I don't think any other program does that.
Steve Bostedor
sbostedor
100
100
Post by sbostedor »
You're right, there are ways to do this through ini files but you have to create a new MSI with every new version release. With a scripted solutions like FastPush, you only need to replace the files in the folder and rerun the script as opposed to recompiling and MSI and adjusting custom setttings in ini files.
I believe that both have their usefulness. I'll create some freeware msi files and post them on vncscan.com soon. I think that, although MSI deployment isn't for everyone, there's certainly a place for it and you shouldn't have to purchase a commercial product for it (including VNCScan).
Steve Bostedor
