UltraVNC 1.7.1.X-dev - Feedback
Locked
RudiDeVos
Post by RudiDeVos »
Feedback for UltraVNC 1.7.1.X-dev in this topic.
UltraVNC 1.7.1.11-dev:
- https://uvnc.eu/download/1710/UltraVNC_17111-dev.zip
- https://uvnc.eu/download/1710/UltraVNC_ ... _Setup.exe
Important:
UltraVNC 1.7.1.x versions have compatibility with previous UltraVNC versions:
- If UltraVNC version has not the FT Protocol 4, it used the FT Protocol 3
- Of course, improvements from FT Protocol 4 will be not present
Changelog:
Version 1.7.1.11 – March 2026
- CVE-2026-3787 fix: https://forum.uvnc.com/viewtopic.php?t=38155
Version 1.7.1.10 – March 2026
- FT unicode
- FT fail on RDP fix
- Use system fonts for chat
Version 1.7.1.9 – March 2026
- FT unicode
- FT flag unaccessible folders red
- Used secure copy_s functions
- Loadlibrary limit path search
Version 1.7.1.7 – Feb 2026
- Copy/Paste removal
- Dialog FT extended
Version 1.7.1.6 – Feb 2026
- Longer hostfield
- Copy/Paste 2 way
- FT mark unaccessible red
- Save load config file fix
- Accept/refuse: Query is now the default
UltraVNC Changelog
Version 1.7.1.5 – Feb 2026
- Speedup FT
- Color cursors fix
- FT and unreadable folders fix
- Viewer loading/saving settings, encryption saving, buffer overrun fix
- Viewer larger host field
Version 1.7.1.1 – Jan 2026
- Unicode for Chat
- Copy/Paste Files
- Listening mode fix
Version 1.7.1.0 – Dec 2025
- FileTransfer optimized (2x faster minimum)
- Bridge mode
- Translations (DE ES FR ZH)
- Use proper ini path (ultravnc.ini) + portable
- Accessibility enlarged cusor show a black rectangle fix
- IPv6 fix
- Use Only Default ConfigFile fix
- Quickoptions fix
- Baseline lib updates:
* libjpeg-turbo: 3.1.2
* liblzma: 5.8.1
* openssl: 3.6.0#3
* zlib: 1.3.1
* zstd: 1.5.7
Translations:
Sainsuper
Re: UltraVNC 1.7.1.X-dev - Feedback
Post by Sainsuper »
How - bridge-mode woks? this is only screen or there is already a beta?
RudiDeVos
Post by RudiDeVos »
@Sainsuper: Not official, but files are online for certification testing:
- https://uvnc.eu/download/1710/UltraVNC_1710-dev.zip
Bridge works like our own P2P until we made but now we use a better library https://librats.com/, it make use of google servers instead of our own.
Sainsuper
Post by Sainsuper »
I'm trying the bridge feature, but it doesn't seem to work. UltraVNC Viewer stays on this screen.
I know it's still an alpha feature but I think that from a graphical point of view the bridge code should be visible more clearly.
RudiDeVos
Post by RudiDeVos »
@Sainsuper: You are correct... seems I broke something while updating the library.
RudiDeVos
Post by RudiDeVos »
Description updated
RudiDeVos
Post by RudiDeVos »
Description updated
Ludovic
Post by Ludovic »
UltraVNC 1.7.1.5-dev build is here to be tested.
Go in main description.
ddbivens
80
80
Post by ddbivens »
About the new file Copy options....
I am connecting to my work PC from home via an Anyconnect connection. I am using a 50 Mbps connection, which is not bad.
When I copy a file on my home PC, say the file: UltraVNC_1716_x64_Setup.exe, even if the copy/paste is for the local hard drive to a local flash drive, I get the message "Connection dropped, trying to reconnect." and my ultravnc connection fails then reconnects.
Am I supposed to be able to copy a file locally then paste the on the remote PC or vice versa? Should copying a file locally cause my UltraVNC connection to fail/reconnect?
RudiDeVos
Post by RudiDeVos »
@ddbivens: Where you testing 1.7.1.6?
FT using copy/paste.
I tested both on LAN.
I using a 1.2 GB file.
FileTransfer: Do you get a popup with the filename and progress?
local CTRL+C and remote CTRL+V?
or
remote CTRL+C and local CTRL+V?
or
Both?
At the bottom, you can find some images:
- https://github.com/ultravnc/UltraVNC/issues/189
testing on wan i noticed thet the ft updates seems to generate artifacts in the encoder...could it be that ?
viewer to server
IGNORE i was testing wityh an RDP session and forgot to disable the RDP clipboard... so i was actual seeing this.
ddbivens
80
80
Post by ddbivens »
Yes, I am using 1.7.1.6 on both ends.
I was able to copy one small file on the local PC using Ctrl-C, I waited a few minutes then I pasted the file using Ctrl-V on the remote PC and the file pasted to the remote PC.
I tried to copy a very large file on my local PC using Ctrl-C and immediately the UltraVNC window displayed: UltraVNC Viewer - Connection dropped, trying to reconnect (3) (Not Responding). After several minutes it started responding again. I tried to paste this file on the remote PC. However I was prompted asking if I wanted to replace the previous small file I had already pasted.
I tried again by selecting a small file again then two medium sized files and when I click on the UltraVNC window it either shows: UltraVNC Viewer - Connection dropped, trying to reconnect (3) (Not Responding) or the UltraVNC window shows gray on the bottom two thirds of the window. I was not able to get another file to paste in the remote PCs folder.
My biggest concern is that copying a large file when the UltraVNC Viewer is connected causes the connection to drop, even if my purpose is to copy/paste from a local drive to a local drive.
RudiDeVos
Post by RudiDeVos »
@ddbivens: I need to work as RDP.
CTRL+C just inform Server.
CTRL+V Server need to request Viewer to send file.
A progress dialog needs to show what's going on.
Not finished, redesiging...
RudiDeVos
Post by RudiDeVos »
Don't get copy/paste proper working.
Update FT window:
- Unicode support
- Unaccessible folders are red
UltraVNC 1.7.1.10-dev:
- https://uvnc.eu/download/1710/UltraVNC_17110-dev.zip
Ludovic
Post by Ludovic »
proger16
Post by proger16 »
Will the new viewers FT be compatible with older server versions (at least with the previous release 1.6.4.0)?
Looks like they won't. At least not with localized folder names.
Don't you think it's a good idea to ensure compatibility between FT, the new viewer version, and older server versions? It would have to be copied to the hosts that are only accessible through it... Switching wouldn't be very convenient, especially if there are a lot of hosts.
RudiDeVos
Post by RudiDeVos »
@proger16: The goal is that the new FT use protocol 3 when protocol 4 is not supported.
kannweg0815
Post by kannweg0815 »
RDP mode is broken in 1.7.1.11.
In 1.7.1.6 it still worked.
RudiDeVos
Post by RudiDeVos »
kannweg0815 wrote: 2026-03-19 14:28 RDP mode is broken in 1.7.1.11.
Explain, what isn't working:
- RDP Server
- RDP session on a normal PC
Ludovic
Post by Ludovic »
@kannweg0815: Please explain your problem, it is needed to fix it...
kannweg0815
Ludovic wrote: 2026-03-29 04:17 @kannweg0815: Please explain your problem, it is needed to fix it...
I will first try the new 1.8.0.0 release.
Maybe the bug is fixed there already.
I will let you know in the 1.8.0.0 feedback thread.
proger16
Post by proger16 »
Rudi De Vos wrote: 2026-03-14 22:48 The goal is that the new FT use protocol 3 when protocol 4 is not supported.
When I tried it, all localized names are displayed as "??????????" (new viewer and old server)
Ludovic
Post by Ludovic »
Dear all,
Can you test the UltraVNC 1.8.x release build?
- https://forum.uvnc.com/viewtopic.php?t=38158
Please comment in the specified topic.
Thanks in advance.
Locked
