listening mode stopped working after update to 1.7.1.0 x64
nagysifa
Post by nagysifa »
Hi!
First of all thank you for developing this essential networking tool!
I have been using listening mode (UltraVNC reverse connection) for many months with version 1.6.4.0 on my server with command from a batch file:
START "" "C:\Program Files\UltraVNC\vncviewer.exe" -listen 55500
after updating to 1.7.1.0 the clients can no longer connect... (the firewall/router connections are not changed)
After reverting to 1.6.4.0 version everything works again...
These window appear instead of the remote desktop:
Thanks for any help or suggestion!
Re: listening mode stopped working after update to 1.7.1.0 x64
Thanks for the feedback!
1.7.1 is still alpha, only use for internal testing.
Was viewer and server replaced or only the viewer?
This limit the bug chase.
nagysifa
Post by nagysifa »
Thank You for the quick reply.
I installed both of them.
I think I found it... one "}" at a wrong place in coded LOL
Will post an update for testing.
This also include:
- unicode chat
- copy paste of a file, could be handy if you quick want to copy a small file
nagysifa
Post by nagysifa »
Great! Eager to test it!
And thanks for all the work you put into this!
nagysifa
Post by nagysifa »
Thank you for the quick reply!
I installed the file (UltraVNC_1710_x64_Setup.exe) to my server
Started the listening mode (as always): START "" "C:\Program Files\UltraVNC\vncviewer.exe" -listen 55500
unfortunately it still do not work:
I tried it with 1.6.4.0 and 1.7.1.0 on the client side...
Can't repeat it.
START "" "C:\Users\XXX\Desktop\git_ultravnc\vncviewer\Debug\vncviewer.exe" -listen 55500
this show the viewer on the systray, and i can proper connect:
Possible it's related to save config settings.
When do you get the dialog, on start or when the server connect?
see config and rename the options or other config files to test:
nagysifa
Post by nagysifa »
I get the error window after I initiate the connection on the remote client...
I will try your suggestion and get back to you.
basso
Post by basso »
I have the same problem.
It occurs when the connection starts.
nagysifa
Post by nagysifa »
Thank You for the fix! It work now as expected!
Ludovic
Post by Ludovic »
@nagysifa: Thanks for your test and your confirmation :)
@basso: Have you tried the 1.7.1.1-dev build?
basso
Post by basso »
File transfer is not working.
basso
Post by basso »
File Transfer work fine
Congratulations
Best Regards
Luis Fernando
