UltraVNC 1.2.1.1 RC2 - Download links
http://www.uvnc.eu/download/1211/uvnc_1211RC2.zip
bins
XP: All OS from XP to win10
win8-win10: use new desktop duplication engine, if this fail use XP
ipv6: Version that should be able to use ipv6 adressing ( experimental)
DPI aware: scaling issue (servers)
vnchook.dll corrected version number
I was only able to test ipv6 on localhost, my isp doesn't support it.
bins
Re: 1.2.11 rc2
~ R
I've tested the 32 bit 1.2.11rc2 "XP" version of winvnc.exe for several hours wrapped in my reverse connection software... Successfully controlling both 32 and 64 bit PCs running Windows 10, 8, 7 and XP. This one version ran smoothly during this short test across all systems tested.
More specifically I wanted to see if the DPI awareness (zoom/scaling) mouse issue I had mentioned was resolved... Happy to report for my short tests, I did not experience an issue with the DPI awareness. The mouse worked fine and aligned correctly.
So at first glance... Currently the 32 bit 1.2.11rc2 "XP" winvnc.exe is my go to single version to wrap in reverse connection software to allow control of any Windows 32 or 64 bit machine Windows XP through Windows 10
If I come across any major unreported issue as I accumulate higher hours, I will update you.
Thanks Rudi and all who contribute.
CPC
*Update...my tests were IPv4 only
CPC
Re: 1.2.11 rc2
parameter "DisableTrayIcon=1" does not work
Re: 1.2.11 rc2
I'm testing 1.2.1.1rc2 viewer against winvnc 1.2.0.9. Previously I used an older viewer version, don't know exact which one I must confess.
With new viewer I had to disable directx=1 because this implies "scale server to window" which leads to terribly bad looking stretched views. Even when the serves screen is smaller than the viewers one.
Question: Since when directx=1 implies "scale server to window"? Maybe a longer time, I'm just interested. And why needs the usage of directx scaling the server to viewers window?
Re: 1.2.11 rc2
And, remembering the viewers last window position leads also to remember the last screensize, which makes no sense at all. This leads to having always black borders or scroll bars. Or, like I wrote above, to stretched views without a need to stretch. Is this by design?
Re: 1.2.11 rc2
I just renamed "directx" to "scale to window" because it better illustrate what the option does.
This option exist already for 5 years, but was default off, now it's on.
I used it to minitor cpu's, multiple viewers with important bigger.
stretch to window make it easy to position the screens. And for stats, the deformation doesn't matter
it's just another x y as scaling.
Re: 1.2.11 rc2
When i restart my 5 viewers, they all open at there previous position and with there last size.
The save position + size is saved as a hostname parameter.
Yes this was made on request, it's just an option you always can disable it.
Re: 1.2.11 rc2
Perhaps we better put all new options off and keep previous defaults.
But this would make it harder to get feedback on it...
Re: 1.2.11 rc2
Our customers servers are nearly every time called "SERVER"... For us this default makes less sense. How is this parameter called in INI ? EDIT: SavePos=1
LOL, now you got feedback! Just kidding... Perhaps it is really better to keep the old default behaviour. At least in release builds. For RCs and betas it doesn't matter.
Re: 1.2.11 rc2
Within options.vnc I see:
Where is the hostname? And, saving the window position is generally a good idea. E.g. when the admin has multiple monitors. But saving the screens width and height not always...
[ID]
x=309
y=156
w=1937
h=1147
Re: 1.2.11 rc2
I appreciate your feedback even all changes were already done in previous versions.
The bin zip now is auto generated with a single push, easy to make changes without the risk to post old version
Defaults are easy to modify.
O yes, you are using ID's, in that case it's called ID.
(With a repeater the hostname is ID and port is ID#...)
But when you are using hostnames it works.
This is to hard to change, it current stay like this
[localhost]
x=309
y=156
w=1937
h=1147
[uvnc.com]
x=309
y=156
w=1937
h=1147
Let see if i can split size and pos with 2 [v]size [v]pos, so you can select what you want to save.
And saving only the position it wil not conflict with the other scaling settings.
[localhost]
x=309
y=156
w=1937
h=1147
[uvnc.com]
x=309
y=156
w=1937
h=1147
Re: 1.2.11 rc2
viewez updated with split pos/size and default scale to window off
Re: 1.2.11 rc2
DisableTrayIcon=1 working, just tested in application and service mode.
Re: 1.2.11 rc2
thx rudi.
The months before I had no time for testing anything. I threw the exe in %programfiles%\uvnc, noticed some irritating changes and reverted to the previous version. That's been all I was able to do.
Now I'll look a little bit deeper inside. I hope.
Re: 1.2.11 rc2
Next thing, already reported in 1.2.0.9, but never solved:
https://forum.ultravnc.net/viewtopic.ph ... t=0#p99210
Starting a .vnc File the viewer always detects the best setting itself, even though .vnc file contains autodetect=0
Re: 1.2.11 rc2
I've got the same problem with DisableTrayIcon not working, but only on my xp vpc's, the w7,w8,w10 ones are hidden.
I'm also having some kind of slowdown problem on that xp when uvnc is connected, everything get's extremely slow but it's not the uvnc binary that's using al the cpu,
other apps like task scheduler suddenly uses 50-100% cpu, like having an interrupt problem.
Re: 1.2.11 rc2
Only tested hidden icon on win7, not xp. will try it on a VM.
Slowdown:
HOw doyou capture
*mirror driver
*vnchooks.dll
Both can have an impact on other applications.
ARe you also using the vnchook.dll provided in this bin zip ?
R.
Slowdown:
HOw doyou capture
*mirror driver
*vnchooks.dll
R.
Re: 1.2.11 rc2
I'm using the vnchooks.dll from the 32 dir in the zip, not using the mirror driver. After removing the dll and restarting the slowdown is gone.
Enabling the mirror driver also seems to solve the problem.
Re: 1.2.11 rc2
Regarding SaveSize=0:
If you start a .vnc file, which not explicitly sets SaveSize=0, the default is: save the size. After this, the size is written to options.vnc. After this, size will be applied to all matching hostnames, which in case of using repeater=ID is every time given. Regardless of how SaveSize is set or not.
So, once you start a .vnc file the "old" not splitted behaviour is back. Only solution is changing the default to SaveSize=0 or changing all .vnc files.
Our .vnc files are generated dynamically and it would be no problem to explicitly set SaveSize=0 centralized. But what do others with tons of static vnc files?
EDIT: The bug seems to be that SaveSize=0 within options.vnc is not respected as default in case SaveSize is not explicitly set within the .vnc file.
Re: 1.2.11 rc2
defaults
m_SavePos = false;
m_SaveSize = false;
m_Directx = false;
m_SaveSize = readInt("SaveSize", m_SaveSize, fname) != 0;
If value not set, default is used.
I'm testing with options.vnc that's not the same as loading a .vnc
Because in that case you merge the settings from options.vnc with your own .vnc file.
Need to check it
EDIT
test
options.vnc
SavePos=0
SaveSize=0
test.vnc
savepos and savesize not set -> SavePos=0, SaveSize=0
options.vnc
SavePos=1
SaveSize=1
test.vnc
savepos and savesize not set -> SavePos=1, SaveSize=1
Looks like this is working.
Only thing wrong was that the viewer always saved the value
But is only used if set
m_SavePos = false;
m_SaveSize = false;
m_Directx = false;
Need to check it
EDIT
test
options.vnc
SavePos=0
SaveSize=0
test.vnc
options.vnc
SavePos=1
SaveSize=1
test.vnc
Re: 1.2.11 rc2
autodetect and quickoption are a pair
If you set autodetect=0 and quickoption=1 -> autodetect ( first option)
If you set autodetect=0 and quickoption=8 -> manual selection
algorithm
if (quickoption==1) set autodetect=1;
algorithm
Re: 1.2.11 rc2
Sounds like the core of the problem. It's always hard to guess the bug from the artefact. But as long as it points you into the right direction...Rudi De Vos wrote: Only thing wrong was that the viewer always saved the value
Ahh, that's it. In earlier versions 8bit= seemed to have had higher priority, or quickoptions was ignored under some circumstances, or... I just don't know. Something changed. But anyway. Setting quickoption=8 did the trick.Rudi De Vos wrote: if (quickoption==1) set autodetect=1;
THX Rudi
Re: 1.2.11 rc2
You wrote something "was" wrong. But winvnc.exe download didn't change until now. Based on your wording I assumed a code change. Are there any changes to be expected in future, or did 'I misunderstand something?Rudi De Vos wrote: Only thing wrong was that the viewer always saved the value
Re: 1.2.11 rc2
disabletray indeed not working on xp
Found, compiler options
Will be corrected in next update
Re: 1.2.11 rc2
If you wish I'll put it in a own post. But I'm sorry, I'm not able to confirm that SaveSize=0 (which is new in 1.2.1.1rc2) works properly. Don't get me wrong. I'm not pressing here. I'm simply not sure if the problem is identified or already addressed in the meantime. Possibly I only have to wait for a newer RC...
Tested with reverse connections:
test.vnc without any Save-Options:
options.vnc:
Closing the viewer the size is written anyway:
fullscreen=0
autoDetect=0
8bit=1
directx=1
localcursor=1
Scaling=0
ServerScale=1
QuickOption=1 <--- I know, same as autodetect=1
SavePos=1
SaveSize=0
[ID]
x=-1681
y=206
w=1682
h=1052
Re: 1.2.11 rc2
code
if (_this->m_opts.m_SavePos && !_this->m_opts.m_SaveSize) m_pMRU->SetPos(_this->m_host, rect.left, rect.top, 0, 0);
if (_this->m_opts.m_SavePos && _this->m_opts.m_SaveSize) m_pMRU->SetPos(_this->m_host, rect.left, rect.top, rect.right - rect.left, rect.bottom - rect.top);
pos=ON, size=ON save(x,y,w,h)
pos=OFF size=OFF, notsave
retested with only pos set.
[LOCALHOST]
x=2490
y=135
w=0
h=0
Please test with rc3, update numbering this weekend because i didn't know anymore what was the latest online update of rc2 and testing with different version doesn't majke it simpler.
Re: 1.2.11 rc2
I never saw save(x, y, 0, 0). Therefore I assume we are testing different versions. Will continue testing once RC3 is online.
Re: 1.2.11 rc2
It's already online from 7/5/2016
http://forum.ultravnc.info/viewtopic.php?f=71&t=31700
