Bug 1.0.6.5 Login screen not refreshed
alexchevrier
Post by alexchevrier »
I deployed ultravnc 1.0.6.5 on about 2000 computers with a home made msi and I have a problem. The login screen isn't refrehed. You have to click on the refresh button every time you make a change : CTRL+ALT+DEL (refresh), enter username (refresh), enter password and click enter (refresh)...
I tried to uninstall my msi and used the official installer, but the problem is still there. All the following tests were done using the installer and not my msi
When the desktop appears, the problem is gone and the refresh is working.
I tried to reboot and log in on the server computer. Then I used vncviewer to join this server (alreagy logged in) and the refresh is working fine.
I also tried to reboot the computer with the server and wait 5 minutes before login in with the viewer and I still have the refresh problem.
It seems that the problem is really only with the CTRL+ALT+DEL screen
MiG
Re: Bug 1.0.6.5 Login screen not refreshed
Post by MiG »
problem was already there on 1.0.7.0 ...
...it doesn't mean your input is not processed ...
... :-* :crazy: 0:-)
UltraVNC 1.0.8.2
OS: win 8.1,
using uvnc-x64 on WAN + LAN with SecureVNCPlugin64, experienced user
-Current fixing some performance issue,
-Then i need to check the logon window
-Then the new Vista dpi handling need to be added
(Current vnc only show part of the screen and mouse is out of sync when
dpi (125%)is used)
californiajeff
Post by californiajeff »
I can confirm this is a problem. I am experiencing the same trouble.
AndreL
Post by AndreL »
I'm facing the same issue on Windows XP SP3 even when playing with all admin refresh possibilities.
André.
solved in 1076 (beta) but other bug added :(
[topic=15988][/topic]
that bug is solved in this server
[topic=16000][/topic]
Try 10761
The beta us just because it's not full tested, when no big bug found
files are renamed to 106X (stable)
jphutch60bj
Post by jphutch60bj »
Finial Update:
Problem was found in the gnome configuration files, It seems to get corrupted when using not standard configurations of the Desktop.
Alt+CTRL+Backspace on the Servers host corrected the problem.
Also one can remove the .gnome, .gconf, and .metacity files on your
server side and restart to get a default configuration restored.
The problem is not with UltraVnc. :-D
Correction:
There is a vnc display refresh problem connecting with Redhat Linux :
Red Hat Enterprise Linux AS release 4 (Nahant Update 6); using the provided builtin, internal, vncserver to export the root window :0
This may be a configuration problem I will get back on this; -
:Oops:
Is there a 64 bit solution? Refresh problem
I connect to a redhat linix box from other windows sources with ultra vnc viewer just fine. So problems with the Linux VNC server are out the window.
I am running vista 64 home prieimum; Yeah I know, that the problem....
With the OS updates I have noticed that the viewer refresh problem comes and goes. Lately the refresh problem has stayed.
Mike H
Post by Mike H »
Try 10761
Do you have an idea when this will be released as stable version?
