Quiet install of winvnc / setupdrv
Any features you would like to see in UltraVNC? Propose it here
Stefaan Degroote
Post by Stefaan Degroote »
Hi all,
Since the R17 driver release, the setup of the driver prompts you if the install was successful or not. The messagebox has to be closed by clicking ok. Also if you type winvnc -install from the command line, there is a message box.
It would be handy to surpress these notifications with a -quiet option... This is handy in scripts to push the vnc installation.
Cheers,
Grrrippp
lenisham
Silent driver for remote installs
Post by lenisham »
I agree here or has this been done already?
Zenophran
Try this
Post by Zenophran »
I've been looking at it and it's packaged with the Inno setup program.
You need to run it with the following parameters "/verysilent /noreboot" (without the quotes) and that should take care of it.
Z
Guest
Post by Guest »
Yes, that works if you're only installing Ultr@VNC but the mirror driver always displays a message box.
Cobra
Post by Cobra »
About the driver-display-box...
There's a little program that can send keys and stuff to other applications. Sort of an custom automated-install program called 'AutoIt'. You can find it Here.
Your script should look something like:
Run("setupdrv.exe install")
WinWait("Title of info-box")
WinActivate("Title of info-box")
Send("{ENTER}")
After you create an executable of the script, just call the script, and the script will start the driver-setup and push Enter when it finds the info-box. It'll show and disappear in one flash :D
