Hi, I'm new in this stuff, I created a VM using google cloud platform with Ubuntu 18 LTS and used all the following commands to create it:
sudo apt install xfce4 xfce4-goodies
sudo apt install tightvncserver
After everything was completed I started the server and I tried to copy and paste something from my pc to inside the ubuntu or the UltraVNC viewer but it doesn't copy/paste it, I tried CTRL + C from inside the viewer to my PC and it doesn't give me the clipboard. What should I do in this case?
Thanks in advance!
PD: I only installed the UltraVNC viewer, not the vnc server and the other stuff because I think I don't need them.
