A recent version has gotten rid of "Scale To Window" as a default option for the viewer.
I'm curious why and if I can configure it using the config file. It's really a pain to have to connect, right-click the title bar, choose connection options, then check the box. Every time I connect to a host...
What happened to "Scale to Window" global option?
Re: What happened to "Scale to Window" global option?
There are no global settings, all settings are now saved at server level.
Scolling through the mru list, also change the settings with them.
