Hi! I will create a topic in multiple languages. I have a question;
Portuguese:
Teria alguma forma de gerar um relatório de acesso, a partir do pessoal que fez alguma conexão por data no VNC?
Tipo um Logon e Logoff. Preciso de um relatório com estás informações. Aguardo.
English:
Would there be any way to generate an access report, from the people who made a connection by date in VNC?
Type a Logon and Logon. I need a report with this information. Wait.
Espanhõl:
Habría alguna forma de generar un informe de acceso, a partir de las personas que hicieron una conexión por fecha en VNC?
Escriba un inicio de sesión y un inicio de sesión. Necesito un informe con esta información. Esperar.
French:
Y aurait-il un moyen de générer un rapport d'accès, à partir des personnes qui ont établi une connexion par date dans VNC ?
Tapez une connexion et une connexion. J'ai besoin d'un rapport avec ces informations. Attendez.
[QUESTION] Report Generator
Re: [QUESTION] Report Generator
mslogon.log in the vnc folder contain the connection info
Found it, thank you very much.Rudi De Vos wrote:mslogon.log in the vnc folder contain the connection info
How does this LOG work?
Does it pick up connections from server machine to client machine?
The server record the viewer connections: Success ip/start/stop
The server record the viewer connections:Fail ip/time
If you use user/passwd the user is also logged
For outgoing connections i need to check, if it's logged or not.
Thank you very much!Rudi De Vos wrote:The server record the viewer connections: Success ip/start/stop
to the next
