[BUG] Mirror driver remove aero
Du10
Post by Du10 »
Hello.
Server: Windows 7x32
Server Settings:
Server config:
[admin]
UseRegistry=0
SendExtraMouse=1
Secure=0
MSLogonRequired=0
NewMSLogon=1
DebugMode=0
Avilog=0
path=C:\Program Files\UltraVNC
accept_reject_mesg=
DebugLevel=8
DisableTrayIcon=0
rdpmode=0
LoopbackOnly=0
UseDSMPlugin=1
AllowLoopback=1
AuthRequired=0
ConnectPriority=1
DSMPlugin=SecureVNCPlugin.dsm
AuthHosts=
DSMPluginConfig=SecureVNC;0;0x00104001;
AllowShutdown=0
AllowProperties=1
AllowInjection=0
AllowEditClients=0
FileTransferEnabled=1
FTUserImpersonation=1
BlankMonitorEnabled=1
BlankInputsOnly=0
DefaultScale=1
primary=1
secondary=0
SocketConnect=1
HTTPConnect=0
AutoPortSelect=1
PortNumber=5900
HTTPPortNumber=5800
IdleTimeout=0
IdleInputTimeout=0
RemoveWallpaper=1
RemoveAero=0
QuerySetting=2
QueryTimeout=0
QueryDisableTime=0
QueryAccept=0
QueryIfNoLogon=1
InputsEnabled=1
LockSetting=0
LocalInputsDisabled=0
EnableJapInput=1
EnableUnicodeInput=0
EnableWin8Helper=0
kickrdp=0
clearconsole=0
service_commandline=
FileTransferTimeout=1
KeepAliveInterval=5
[admin_auth]
group1=
group2=
group3=
locdom1=0
locdom2=0
locdom3=0
[poll]
TurboMode=1
PollUnderCursor=1
PollForeground=1
PollFullScreen=1
OnlyPollConsole=0
OnlyPollOnEvent=0
MaxCpu=40
EnableDriver=1
EnableHook=1
EnableVirtual=0
SingleWindow=0
SingleWindowName=
[Permissions]
Client Settings:
Problem: I don't want aero to be removed, but it's removed! "Remove Aero (Vista)" is unchecked (as u can see on the screenshot).
OK. if I uncheck "Mirror Driver" - then, aero will not be removed.
I think, this is bug, can u fix it?
Re: [BUG] Mirror driver remove aero
No bug:
A mirror driver actual put the system in basic video mode ( this is how it's implemented by MS).
In basic video mode you switch to the XP style and Aero doesn't exist.
From windows 8 we use the ddengine and this works with directx.
MS actual made the old mirror driver working on Vista and windows 7 by putting the whole video system in xp mode. Later they added a new method (ddengine) to capture the screen), but never made it compatibel with Vista and win7.
Du10
Post by Du10 »
ok, then I will disable Aero forever using GPO.
Du10
Post by Du10 »
And that's how we can disable Aero with GPO
1. User Configuration -> Preferences ->Windows Settings -> Registry
Set
HKEY_CURRENT_USER\Software\Microsoft\Windows\DWM\Composition
to value 0
2. User Configuration\Administrative Templates\Control Panel\Personalization\Prevent changing theme
Set to Enable
