Mirror Drive Not Activated
RedAero
Post by RedAero »
Hi!
As some others, i am also having difficulty getting the mirror driver to activate.
I'm using Win 7 x64 as the server (service mode), Win 10 x64 as the viewer, both UVNC 1.2.2.3.
Server has 3 screens, all 32 bit color depth.
Mirror driver 1.00.22 vistax64 installed separately as admin on server (ran the .bat file as admin). Driver date is 04-11 so seems to eb the correct version. Rebooted twice.
Driver check message is the usual:
Driver found.
Driver version OK
Driver Not Activated, is the viewer current connected ?
A mirrior driver can only be started if winvnc is a service or running as admin.
The server log says:
vncclient.cpp : Leaving InitAuthenticate
vncdesktop.cpp : initialising desktop handler
vncdesktopthread.cpp : Hook changed 1
vncdesktopthread.cpp : Hook changed 2
vncdesktop.cpp : KillScreenSaver...
vncdesktop.cpp : InitVideo driver Called
 --The system cannot find the file specified.
vncdesktop.cpp : Driver option enabled
vncdesktop.cpp : Driver option is enabled
Mon Feb 11 10:22:54 2019
vncdesktop.cpp : Start Mirror driver
 --The specified program requires a newer version of Windows.
vncdesktop.cpp : Start Mirror driver/ddegine Failed
vncdesktop.cpp : Using non driver mode
Mon Feb 11 10:22:55 2019
vncdesktop.cpp : No driver used
vncdesktop.cpp : bitmap dimensions are 5760 x 1080
vncdesktop.cpp : created memory bitmap
vncdesktop.cpp : got bitmap format
vncdesktop.cpp : attempting to enable DIBsection blits
vncdesktop.cpp : enabled fast DIBsection blits OK
vncdesktop.cpp : no palette data for truecolour display
vncdesktopsink.cpp : StartInitWindowthread
vncdesktopsink.cpp : StartInitWindowthread default desk
vncdesktopsink.cpp : InitWindow called
 --The parameter is incorrect.
Thanks in advance for your herp.
Re: Mirror Drive Not Activated
The mirror driver is limited in memory usage, it's kernel memory.
The kernel memory allocation function often refuse when you want to allocate big chunks of memory.
Try with a smaller display to check if this is the case.
