Authentication disabled, only use DSM plugin
masdtaylor
Post by masdtaylor »
I am trying to set up the computers on my work network with VNC. So far things are going well, except for one small thing (small but apparently a deal breaker for my techs). I would like to disable authentication and ONLY use a public/private dsm key set. In my tinkering with VNC (many many many uninstalls/reinstalls, tweaking settings) I got this to work once. But then I uninstalled and started from scratch (to document what i was doing) and it didn't work the second time!
Here are the steps I am following.
1)	Run I:\installs\UltraVNC\1.0.9.6.1\UltraVNC_1.0.9.6.1_Setup.exe
2)	Click “OK” to select English as your language
3)	Click “Next” at the “Welcome to the UltraVNC Setup Wizard” window
4)	Click “I accept the agreement” and then click “Next”
5)	Click “Next” at the information screen
6)	Click “Next” to select the destination (Leaving the default)
7)	Drop down the combobox and select “UltraVNC Server Only” then click “Next”
8)	Click “Next” to select start menu folder (Leaving the default)
9)	Click “Next” for optional add-ons (Leaving the default)
10)	Click “Next” for the Mirror Driver (Leaving the default)
11)	Select all Additional tasks except “Create UltraVNC desktop icons” then click “Next”
12)	Click “Install”
13)	Click “Next”
14)	Click “Finish”
15)	At this point the “UltraVNC Server Property Page” should open.  Change the following settings then click “Apply”, then Click “Ok”
             a.	Remove both “VNC Password” and “View-Only Password”
             b.	Under “DSM Plugin” check “Use” and select “SecureVNCPlugin.dsm” from the list
             c. 	Under Misc check
                        i.	“Enable Alpha-Blending Monitor Blanking”
                       ii.	Capture Alpha-Blending
                      iii.	DisableTrayIcon
                       iv.	Forbid the user to close down WinVNC
16)	An error message will appear warning you that incoming connections will not be accepted because you don’t have a password set.
17)	Leaving that error up, open C:\Program Files\UltraVNC\uvnc_settings.exe
18)	Click the “Authentication” tab
19)	Clear both passwords and click “Disable Authentication” then click “Save to ultravnc.ini”
20)	Click “Yes” to the error that comes up
21)	Click “Quit”
22)	Copy
I:\installs\Mukwonago Remote Console\Server Key\20120110_Server_ClientAuth.pubkey
to
23)	Restart the system.
24)	At this point you should be set to remote control this PC using Mukwonago Remote Console.
The viewer has the corresponding key (20120110_Viewer_ClientAuth.pkey) in the same directory as it.
Any help you can provide would be VERY appreciated!
Thanks in advance,
Taylor
