I am connecting to a workstation with dual screens.
When I am in full-screen mode the horizontal scrolling doesn't work. I put my mouse to the complete right and then I only slide about 10% before it stops. Sliding to the left seems to be even more difficult.
It is also a bit annoying to have to continually switch between full-screen and windowed mode to use the horizontal scrollbar.
So my question is. Can I do something to make the horizontal sliding work well?
Or is there a hotkey that I can use to switch between the two screens?
Thanks in advance...
