Dear Sirs,
I would like to display a touchscreen running under Windows CE 5.0 on the screen of a notebook running under Windows XP.
On the Server side, (Windows CE 5.0), which UltraVNC SC program should I use?
winvnc_SCII_100.exe
winvnc_SCII_RC23.exe
winvnc_SCIII.exe
On the Client side, (Windows XP), which program should I use?
UltraVNC_1_2_01_X86_Setup.exe
vncviewer_ssl.exe
Thank you very much for your help.
Best regards,
Tomas.
UltraVNC SC miniServer under Windows CE
Re: UltraVNC SC miniServer under Windows CE
doesn't work, CE is other OS the windows.
You can not recompile windows source for CE
