No remore desktop, just terminal window
goldfazer
Post by goldfazer »
Hi, I've just installed Debian Wheezy on a server, installed vnc4server and started it.
UltraVNC (windows 7 64bit) connects fine and I can access a remote terminal window. However, I have no 'desktop' access i.e. no list of apps (iceweasel etc.).
What have I missed?
Thanks.
Re: No remore desktop, just terminal window
On debian you need to define what you want to share, normal the vnc server use some .vnc ini file
In this file you need to define what he share.
Try to google for "debian vnc full desktop"
See
http://forums.fedoraforum.org/showthread.php?t=92496
goldfazer
Post by goldfazer »
Cheers.
