Single Window Mode
lvx
Single Window Mode
Post by lvx »
Hi to all!
Somehow the 'Select Single Window' feature doesn't work on my computers.
Maybe I'm doing something wrong: after successful connection to a remote desktop I push the 'Select Single Window' button (cursor changes) and then select the window that I need. Nothing happens when I choose the window, except the cursor (it changes back when I click). I've tried to select different parts of the window, tried to select different windows (notepad, google chrome), I even tried different bandwidth options - nothing changes.
Searched the forum but didn't find any topics about this problem.
Please, help! :oops:
Re: Single Window Mode
Hi -- the term you want is "seamless window".
https://forum.ultravnc.net/search.php?k ... ess+window
lvx
Post by lvx »
Thank you very much.
commander_keen
Post by commander_keen »
It seems that this functionality is broken for quite some time now according to the forums.
Is there any progress being made or even worked at it?
Otherwise you should remove that button, it's plain nonsense for over a year now(?)
