Hello
I have no idea how this UltraVnc program got on my PC. It keeps popping up the Ultra@VNC Server Property Page and no matter how I try I cannot remove it or the program from the Folder in the C:
Nor is there a file for uninstalling in the program file directory.
How can I totally remove this software program and including all traces of the program from my PC.
Help and thanks in advance.
Steve
UltraVNC - how to remove
Re: UltraVNC - how to remove
Only after looking through Add/Remove Programs (in Control Panel) you do not find UltraVNC, or VNC anything, do the following:
Open Task Manager and look for the service (processes tab). Stop everything that has "vnc" in it. Then go back to your programs directory and delete the folder with the program in it. Open regedit(start>run>regedit.exe>enter) (don't do this if you are not comfortable with doing so) (if you have no idea what it is... don't delete it) and start at the top of the tree. Do a "Find" for "vnc" and delete everything in the registry that refers to vnc. When you get to the end of the registry, and find no more entries for "vnc", restart your computer.
Download and register "Registry Mechanic". Scan your registry. It will go in and find left over errors (there will be some). Once it completes, restart your computer again.
You should have no more problems
William Boyd, Jr.
Moderator, The Job Hunter
Product Marketing Manager
Microsoft Authorized Refurbisher
Boyd IT Consulting
http://www.boyditconsulting.com
Wisconsin Tech's Group
http://www.brightfuse.com/Groups/WItechs
Boyd IT Consulting
Hi all,
I'm not able to stop the winvnc.exe program at my task manager. it says access denined.
I dont know how this UltraVNC software came into my system and its bugging me a lot.
Somebody help me to get rid of this junk software and its keep on popping up the server property page.
Pls help urgently.
Love,
Sakthi,
India.
Pls help urgently.
Love,
Sakthi,
India.
Hi,wboyd50 wrote:Only after looking through Add/Remove Programs (in Control Panel) you do not find UltraVNC, or VNC anything, do the following:
I'm unable to stop winvnc.exe task at taskmanager.
The ultravnc server property page is keep on popping up and its bugging me a lot.
Pls help urgently.
If ultravnc is installed by our installer, you just have to uninstall it via the remove programs.
But some remote support programs from dell and other vendors include a copy of ultravnc. Then it's installed
as part of there program and does not have a seperate uninstaller.
I guess ultravnc is running as service, stopping winvnc.exe wil not help as the service restart it.
1) Stop the service
open a cmd ( runas admin)
net stop uvnc_service
2) search your program files for winvnc.exe
just rename the file winvnc2.exe and reboot
1) Stop the service
