I need help, somehow ultravnc 1.0.2 keeps showing up when I do a yahoo antispyware scan, I remove it but ultravnc is still there. I did not download this onto my computer and don't know how it got there.
Can anyone tell me how to get this program out of my computer once and for all? It is not located in the add/remove area of my computer so I don't know where to go to uninstall this annoying program.
[mod=3406,1189213828] removed the bolding [/mod]
Removing UltraVNC 1.0.2
Re: Removing UltraVNC 1.0.2
This program is not annoying first off is this on your work computer or a personal one..
This application does not install itself nor does it contain any spyware.
windows defender also detects uvnc now that microsoft and yahoo are buddies i can see why the scan is saying that.
If it is a work computer talk to your ist department
they maybe using it.
If it a home computer
open the command prompt and c:\Program Files\UltraVNC\winvnc -uninstall
once that is done delete the c:\Program Files\UltraVnc\
delete the registry keys
[HKEY_LOCAL_MACHINE\SOFTWARE\ORL]
[HKEY_LOCAL_MACHINE\SOFTWARE\ORL\WinVNC3]
[HKEY_CURRENT_USER\SOFTWARE\ORL
User not developer..
