2026-09-13: After more 5 000 000 (five million) views on forum for 1.8.x.x development versions...
A new stable version, UltraVNC 1.8.2.9 (2026-09-07) and 1.8.3.0 have been released: viewtopic.php?t=38204
w8hook.dll crashes SC in a laptop/tablet computer
lwc
Post by lwc »
I can't use SC in a Windows 10 laptop/tablet combo computer because w8hook.dll always crashes.
In other words, it's similar to https://forum.uvnc.com/viewtopic.php?t=31253, but with (the latest) SC.
It works fine if I use an older SC that uses SCHook.dll & vnchooks.dll instead of w8hook.dll.
Can you please help?
Update: this plugin was eventually removed from the program.
Log Name:      Application
Source:        Application Error
Date:          29/12/2017 14:29:43
Event ID:      1000
Task Category: (100)
Level:         Error
Keywords:      Classic
User:          N/A
Computer:      {computer}
Description:
Faulting application name: winvnc.exe, version: 1.1.0.0, time stamp: 0x57324289
Faulting module name: w8hook.dll, version: 0.0.0.0, time stamp: 0x5730f16d
Exception code: 0xc0000005
Fault offset: 0x0000c7ce
Faulting process id: 0x324
Faulting application start time: 0x01d380a0a7600f57
Faulting application path: C:\Users\{user}\AppData\Local\Temp\IXP000.TMP\winvnc.exe
Faulting module path: C:\Users\{user}\AppData\Local\Temp\IXP000.TMP\w8hook.dll
Report Id: 2f10706c-6c3b-4a0b-8876-e805048975b5
Faulting package full name:
Faulting package-relative application ID:
Event Xml:
<Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
  <System>
    <Provider Name="Application Error" />
    <EventID Qualifiers="0">1000</EventID>
    <Level>2</Level>
    <Task>100</Task>
    <Keywords>0x80000000000000</Keywords>
    <TimeCreated SystemTime="2017-12-29T12:29:43.588093100Z" />
    <EventRecordID>989</EventRecordID>
    <Channel>Application</Channel>
    <Computer>{computer}</Computer>
    <Security />
  </System>
  <EventData>
    <Data>winvnc.exe</Data>
    <Data>1.1.0.0</Data>
    <Data>57324289</Data>
    <Data>w8hook.dll</Data>
    <Data>0.0.0.0</Data>
    <Data>5730f16d</Data>
    <Data>c0000005</Data>
    <Data>0000c7ce</Data>
    <Data>324</Data>
    <Data>01d380a0a7600f57</Data>
    <Data>C:\Users\{user}\AppData\Local\Temp\IXP000.TMP\winvnc.exe</Data>
    <Data>C:\Users\{user}\AppData\Local\Temp\IXP000.TMP\w8hook.dll</Data>
    <Data>2f10706c-6c3b-4a0b-8876-e805048975b5</Data>
    <Data>
    </Data>
    <Data>
    </Data>
  </EventData>
</Event>
