Why is ULTRAVNC asking for a username when I try to connect?
Should you have problems with the MS logon plugin, here's the place to look for help or report issues
wdweldon
Post by wdweldon »
I am trying to connect to a ULTRAVNC server and for some reason it is asking me for a username? I did not setup the server on this PC because normally VNC only asks for a password?
davidweldon@email.com
bevtech
Re: Why is ULTRAVNC asking for a username when I try to conn
Post by bevtech »
ucheck your mslogon settings and use only classical autheniction.. If you dont want username and passord
Tip:
If using Xp home the mslogon II or new mslogon will not function have to only use mslogon... :idea:
User not developer..;)
