Cant connect after I enable DSM plugin
Should you have problems with the DSM plugin? Here is the place to look for help or report issues
Cooge
Post by Cooge »
I have installed the DSM plugin but when I click on the "use dsm plugin" and enter the password nothing happens.
If I take out the tick I can connect no problem. Where am I going wrong?
COOGE
bevtech
Re: Cant connect after I enable DSM plugin
Post by bevtech »
Do you have the same version of the plugin on both the server and viewer side??
Do you have the dsm plugin in the uvnc directory and not the plugin directory??
User not developer..;)
Cooge
Post by Cooge »
I have the same version installed on the viewer and the server. I Think.
When I go into the properties of each it appears to be the same. Is there a way I can check other than the properties page?
COOGE
