-sc_prompt through service mode
jbcollins
Post by jbcollins »
I'm hoping someone has an answer to this as its really confusing me.
I am using command line arguments to create a reverse connection. I'm looking to get the same functionality as single click where the viewer gets a prompt asking if they want to accept the connection or not. The only problem is the connection comes through in application mode even though I run the command on the service executable. If I take out the -sc_prompt argument it then comes through in service mode but it doesn't prompt the viewer, it just connects.
Is there a way to create a reverse (service mode) connection with a prompt on the viewer side?
