Ultr@VNC is so useful to me as I need to access files on other computers fairly often and then I use it to transfer an offsite backup at the end of the day.
The ability to synchronize files across two computers via Ultr@VNC would be very useful as it would save a great deal of time.
Anybody else agree?
(I haven't missed this feature somewhere, have I?)
FR: File Synchronization
if by synchronize you mean copy... then y not just copy over the files via file transfer before doing something.
If you want automation over WAN link non domain connected computers sort of like the offline files with MS... I don’t think this product is supposed to help you with the synchronization of files, more as a handy way to get a file / dir over to someone’s computer that you are remotely viewing.?
Re: FR: File Synchronization
I agree. File synchronization, defined as the ability to look in directories on two computers and automatically replace older versions with newer ones, would be useful. It would be of use to anyone who works on the same files on two different computers, which is probably most of us who use ultravnc.
It exists in commercial programs. I can't understand why it has not already been implemented in ultravnc.
Bernard Weiss
