2026-09-07: After more 5 000 000 (five million) views on forum for 1.8.x.x development versions...
A new stable version, UltraVNC 1.8.2.9 has been released: viewtopic.php?t=38203
ServerScale in 1.0.8.2
lawrencealan
Post by lawrencealan »
I use VNC files, and ServerScale seemed to break VNCViewer on connection to a non 1.0.8.2 machine... did something change here?
It also crashes when I set the settings manually via the dialog.
Re: ServerScale in 1.0.8.2
at vncviewer,
could you try delete saved settings then close vncviewer and open again and retry connection manually and change the scale
Only experienced user, not developer
sfhub
Post by sfhub »
I am also having this problem. Whenever I choose ServerScale in the connection options, it connects to the server and my local viewer displays a blank session window, but then vncviewer.exe crashes displaying windows prompt indicating the app crashed.
I am able to use client side scaling and that works fine.
I tried the suggestion above of deleting the saved settings, exiting, and rerunning the viewer and choosing serverscale, and the problem still happens.
100% reproducable every time.
sfhub
Post by sfhub »
Someone else is noticing this problem:
[topic=17965][/topic]
