A new development version, UltraVNC 1.6.3.0-dev has been released, please test it: https://forum.uvnc.com/viewtopic.php?t=38091
bind repeater to one ip
SC <-> Proxy <-> Repeater <-> Proxy <-> Viewer
Greta
Post by Greta »
How can I change the source code so that the repeater is bind to one ip number.
Greta
Re: bind repeater to one ip
Post by Greta »
Is there no one who knows how to bind the repeater to one ip number if the server has several addresses.
I have already searched the internet for this but could find any thing about it
JDaus
Friend of UVNC
Friend of UVNC
Post by JDaus »
if you are running WINXP, you should be able to setup the firewall rule with a limited scope ... its NOT binding it to an IP, but it will do what you want it to do ...
What OS are you running (i presume windows ...)
SecureTech.com.au
Greta
Post by Greta »
It runs on a Windows 2003 server with 16 IP numbers. And the repeater is listening on all ip numbers. So if one ip number use already port 443 then the repeater won’t run any more.
JDaus
Friend of UVNC
Friend of UVNC
Post by JDaus »
ah ... then thats a little different ...
i understand now why you wish to tie it to one IP ...
I have a question (for my own knowledge, not too question you) ... under windows, if a port is in use on a machine (on one or several IPs) can you then use that same port on other IPs ???
i know this can be done in the UNIX / LINUX world, but i thought that windows just reserved the port
SecureTech.com.au
addr.sin_addr.s_addr = htonl(INADDR_ANY);
bind(sock, (struct sockaddr *)&addr, sizeof(addr))
replace INADDR_ANY by the ip of the NIC you want to bind to
This should work if the cards have been setup proper, if ip's on the
cards doesn't overlap.
FAULT SETUP
192.168.1.1 255.255.255.0 -> This card is responsible for direct connections to 192.168.1.X
192.168.1.2 255.255.255.0 ->This card is responsible for direct connections to 192.168.1.X
Both cards serv the same ip range, and bind get confused, possible it will
bind on all cards that can server the ip adress you entered.
Greta
Post by Greta »
JDaus wrote:ah ... then thats a little different ...
Yes you can, if you bind the program to one ip then you can use on an other ip (on the same machine) the same port if you then also bind the program on that specific ip.
Rudi De Vos wrote:addr.sin_addr.s_addr = htonl(INADDR_ANY);
Thanks, I try this.
Greta
Post by Greta »
The binding to the ip number works now. Only I can not connect on SSL anymore. VNC through the normal ports 5500/5901 works perfect. When you see the log it seem everything is alright.
SSL initialized
SSL loading CERTIFICATE.PEM
SSL listener started on port = 443
Anyone any idea?
Greta
Post by Greta »
I have already found it. I was forgotten to change strcpy(tcpCi[0].backEndServerIPAddr, "127.0.0.1");
Great, can you provide the source so we can make it available to other.
This was requested a time ago, by less talented developpers :)
Greta
Post by Greta »
I have placed the ip number hard into the source code. So I don’t think it is usable for everybody. When you want a different ip number you have to rebuild the source.
labarks
Post by labarks »
is this feature of setting the ip address or interface available with the ultravnc server yet?
Greta
Post by Greta »
No idea if that’s also possible whit ultravnc server.
If you want to do what I have done you have to look in the code for addr.sin_addr.s_addr and change INADDR_ANY to your ip number thant you want to use and recompile the code. The program then works only on them machine with that ip number.
