Hi
UltraVNC Viewer 1.1.9.1
UltraVNC server 1.2.0.3
The remote viewer window screen resolution is 1024x768. The physical computer's (server) screen resolution is 1280x1024.
Is there any way to set the screen resolution of remote connection viewer to that of the actual physical computer's (server) screen resultion or to the client's screen resolution?
Resolution
Re: Resolution
NO,
You can use [v] directx viewer option.
In that case the full screen is scaled to the viewer window. But if aspect ratio differ, the screen get deformed.
