2026-09-07: After more 5 000 000 (five million) views on forum for 1.8.x.x development versions...
A new stable version, UltraVNC 1.8.2.9 has been released: viewtopic.php?t=38203
1.0.9.6.2 weirdness with really slow initial screen draws
rcooke
Post by rcooke »
This might be related to another post where the initial screen nevers displays - you just get a solid colour window.
I have 50 or so machines, most use the FreeBSD repeater, some have local port forwards as well. (for when the auto reconnect fails I can remotely restart the service)
A few weeks ago, they all worked perfect. I could connect to any machine from any of my 4 usual work locations. Now, I have a problem connecting via the repeater to remote machines.
The connection establishes normally. But then I get the big, solid colour screen. I hit the connection info icon, and I can see data trickling in. Normally, the initial screen loads up (20-50K?) in a few seconds. Now, I watch the "Rx" data go up a few K at a time. Then it starts to pause every 4K-6K. If I let it go a few minutes, it will creep up to around 12-15K then stop. A little later the connection terminates. I grabbed the console log (before it terminated):
fh is 3
Started and Winsock (v 2) initialised
bufsize expanded to 4352
Registered connection with app
Connected to never.you.mind port 0
DSMPlugin not enabled
Connected to proxy
Connected to RFB server, using protocol version 3.0
RFB server supports protocol version 3.8
Connected to RFB server, using protocol version 3.8
No authentication needed
VNC authentication succeeded
Read a 44-byte string
Desktop name "richardcooke-pc ( 10.0.0.23 ) - service mode "
Geometry 1920 x 1080 depth 32
Screen work area is 1280 x 920
Reset keyboard for first use
Flush dead key gives: 1 character(s): 0x0020 ( )
Requesting 8-bit truecolour
Clipboard changed
Ignore Clipboard while initializing!
No next window in chain; WM_DRAWCLIPBOARD will not be passed
SetClipboardViewer to 0x000c035c; next is 0x00020422. Last error 0x00000000Scree
Update-processing thread started
ServerState- reading 11 bytes
ServerState (2, 5)
New keepalive interval 5Read remote clipboard change
Read remote extended clipboard change
Requesting new pixel format
Receiving cursor shape update, cursor 32x32
bufsize expanded to 16640
I have two workstations at this location (my home actually) one XP PRo machine and one WIN 7 PRO 64-bit machine. Both exibit the SAME behaviour trying to connect to the same two remote machines via the repeater. They can connect to each other direct no problem. Butthe Win 7 one has the same problem with the XP one via the repeater.
When I go to the office, from my Win 7 Ultimate 64-bit machine (which is one of the 2 I'm trying to connect to) I have no trouble connecting to any other machine - including my 2 at home. I can connect to the WIN 7 home machine direct and my XP machine via the repeater. Both work normally.
And I can connect to my desktop from a co-workers' WIN 7 Ultimate 64 bit machine. I think he had no trouble connecting to my direct machine either. And he has no trouble connecting to the remote machine I couldn't get from home via the repeater (an offsite client machine).
I have been searching for "what changed" before this started. Nothing really stands out. The usual MS updates. I started using a VOIP phone at home (which I unplugged for a test to make sure it was not throttling bandwidth).
Doing an http://speedtest.net shows I'm getting near my max speed up and down (5M/800K). I did an FTP test with a machine on the work network, and I got near my max speed up and down - just in case there was a flaky router. (although a flaky router on the work network would not affect my attempt at the client's remote machine from home, but I thought it was worth checking
I'm looking for ideas! An after-thought: Two of the problem machines have really large wide screens attached - a lot of data. At least I used a solid colour background, but still, lots of icons.... Mind you, the offiste client machine has always been a widescreen and used to work just fine. hm. Although now, they keep a security camera display on it, so lots of moving pixels.
If anybody can tell me how to use the encryption plugin on my MAC I would have a 3rd machine at home to try!
Regards,
Richard Cooke
rcooke
Re: 1.0.9.6.2 weirdness with really slow initial screen draw
Post by rcooke »
Regards,
Richard Cooke
