Hello Everyone;
My first time here, so if this is the wrong forum to post this question, plese let me know.
I have small network of PCs running XP-Home, XP-Pro and NT4. I use UltraVnc v1.0.2 to connect between these machines and use the AESV2 plugin with a 40bit encrytion key (as this is the longest NT4 will accept -- AFAIK).
Now, I need to connect to a PC running Vista. v1.0.2 was crashing over and over on Vista, so I installed v1.0.9.6.1. I then read-up on the new SecureVNC Plugin by Adam Walling. I looked at the configuration section for this Plugin, but can't seem to figure out how to connect my XP machine (running v1.0.2) to this one.
FWIW... If I do not use an encryption plugin, I can connect A-OK.
Can anyone point me in the right direction?
TIA.
Charles...
Conencting between v1.0.2 and v1.0.9.6.1
Re: Conencting between v1.0.2 and v1.0.9.6.1
The 102 version doesn't know the new plugin engine, best way is to install old plugins.
