update old sc (online creator) update 27/08
Re: update old sc (online creator) update 27/08
-autoreconnect
If it worked for the old online creator, it is still working.
Is there any particular place you need to add the [DIS_UAC] in the helpdesk.txt file? I assume you only need to enter is once for all hosts, is this correct?
Tim
Tim
-autorecconnect doesn't work, but in the old version there isn't this possibility.
There is a way to use autoreconnect with this update of old sc?
regard
regard
Sainsuper,
How did you make -autoreconnect work in the old version?
Here's my example, you can maybe tell me if it's proper:
It definitely didn't work in Windows 7. I'm not running any batch file, however, like it says in here
subnet99,
How does [DIS_UAC] work? I've never seen anything about that. (edit) Ok, I did see the blurb about it on the previous page. I would also like to know how to implement that.[/code]
[HOST]
(1) Tech 1
-plugin -autoreconnect -connect 192.1.1.1:5900 -noregistry
subnet99,
You obviously lack the creative genius to integrate Legos and Duplos.
I got this same issue when I connected a Win 7 64 bit single click to my 1.0.6.5 viewer on XP 32 bit. I'll be honest: I don't totally understand the issue.ssx4life wrote:Actually this happened on 32bit windows 7 not 64bit.
Is there anything else I can do to help with this? Perhaps give an option when the file is uploaded online for it to be used with 32bt vs. 64bit?
@jogz
-autoreconnect cannot be used in old sc it's an option for full winvnc version
i hope in a RUDI update!!! (with reject )
i have tried [DIS_UAC] after host section and it work. es:
[TITLE]
xxxxx
[HOST]
supporter1
-connect X.X.X.X:5500: -noregistry
[HOST]
supporter2
-connect X.X.X.X:5501: -noregistry
[DIS_UAC]
[TEXTTOP]
aaaaaaaaaaaaaaa
[TEXTMIDDLE]
etc...
[TITLE]
xxxxx
[HOST]
supporter1
[HOST]
supporter2
[DIS_UAC]
[TEXTTOP]
aaaaaaaaaaaaaaa
[TEXTMIDDLE]
etc...
Hi!
Some questions...
Does the user need to press any button to disable Aero on Vista?
How does the Disable UAC works? Will it have to reboot the PC? Will it do it automatically?
Thanks for your reply
I don't have a Vista computer to test on myself.
Also... There is no autoreconnect option?
Why couldn't this be implemented as an option?
Some questions...
1) disable/enable is done auto
2) Disable uac
No reboot needed.
Only on start, the user need to press onces the uac window
(this is needed to change the uac setting)
On logout, all is restored.
2) Disable uac
No reboot needed.
Could someone take a look at this bug:
"vncviewer -listen allows connections from UltraVNC SC clients, but doesn't display the window" - https://bugs.launchpad.net/ubuntu/+sour ... bug/123631
This might be a problem in the Linux vncviewer but since both of them have this problem and only with scnvc, not UltraVNC server, I am not sure.
It would be great if one of the SCVNC developers could take a look at it.
sc is build with the old rfb protocol and use some non official rfb numbers.
( The whole thing was made before the rfb 3.4 was out)
If not using a ultravnc viewer, the viewer should tell he support 3.3 else
the server get confused and connection fails.
Thanks for your fast reply.
Could this be fixed in the updated SCVNC?
i have done other test in windows 7 with UAC enabled, it works very great and fast! one problem.... reconnect function isn't possible??'
Rudi
can you update winvnc 1.0.6.4 --> 1.0.8.0 with the online creator for vista/7, please, thank you
http://support1.uvnc.com/cgi-bin/upload4.pl
How is it possible to use the new SecureVNC plugin with SCVNC?
I have added it to the Scvnc (local created) with the server key but I always get the message that encryption is activated but is not used. Has anyone a howto or is this not possible atm?
I mean the SecureVNC plugin with created keys should be very secure because of the asymetric encryption. With the MSRC4 if you got the exe you got the key so ...
The online creator use a modified version of the original sc.Rudi
This is not 1.0.6.4 or 1.0.8.0 but a modified 1.00 version.
The source tree is complete different and all is build with vc60
to have a very small exe. Changes can't be imported, i only
added some aero and uac stuff.
1.0.8.0 with the -sc_promt commandline is something different.
The way to go in the future.... but still no time to rebuild a new
online creator.
Feature request: allow us to upload our own DSM (I'd like to use Adam Walling's SecureVNCPlugin.dsm). I just created a new SC and then (after it had un7-zipped itself) copied SecureVNCPlugin.dsm over the included MSRC4Plugin.dsm in the %TEMP%\7zxxx.tmp folder. I was then able to connect securely to my listening viewer which is also running SecureVNCPlugin.dsm.
If I could replace the DSM in the downloaded EXE I would just do that ;-)
FWIW here's the top of my helpdesk.txt:
[HOST]
Helpdesk 1 (Encrypted)
-plugin -connect 87.65.43.21:5500 -noregistry
[HOST]
Helpdesk 1 (No Encryption)
[HOST]
Helpdesk 2 (Encrypted)
-plugin -connect 12.34.56.78:5500 -noregistry
[HOST]
Helpdesk 2 (No Encryption)
[HOST]
[HOST]
[HOST]
[HOST]
Angus S-F
GeoApps // Tucson, Arizona, USA
Angus S-F
Forgive me if this has already been answered somewhere, but is it possible to configure SC to allow the remote control party to click on the UAC prompts under Vista/Windows 7? It seems that the console user must approve all UAC prompts before control is returned to SC. I assume there must be some way to implement this, if it has not already been done, because other remote apps, Remote Desktop for instance, allow you to interact with the UAC prompts. Any info. on this is appreciated. Thanks.
Vincent
Rudi de Vos wrote
Vincent
Rudi de Vos wrote
UAC: sc is running as user, this does NOT allow UAC access.
-UAC windows are view only. (you now stay connected in view only mode)
-When the UAC window ( not the popup, the one that has the elevated permission) is closed or minized, you get back full access.
Update 27/08/2009
helpdesk.txt added
[DIS_UAC]
*Adding this option, uac is disabled for admin. If the user who started
sc is admin you know can remote control system apps.
Only applications started by the service, can press the uac prompt.
SC running as application, is blocked by Vista security.
The console user must approve uac ONCE , at least when he is admin
and you have set the [DIS_UAC] in the config file.
If a standard application was able to control uac, there would be no need to enable uac, because a virus would also be able to control it.
I just want to ensure I have understood you correctly. If [DIS_UAC] is placed in the helpdesk.txt file, then the user will need to verify one UAC prompt after which all other UAC prompts will be suppressed? Correct? If not, what is the purpose of [DIS_UAC]? Thanks.
Vincent
Vincent
Correct,
This option set the registry value, "uac popup not required for admin".
This reg change is the actual popup you get once on startup.
After the change no other will appear.
When SC close, the old value is restored.
pittdaydreamer wrote:is it possible to configure SC to allow the remote control party to click on the UAC prompts under Vista/Windows 7?
Try using scprompt or similar application that supports service mode ...Rudi De Vos wrote:Only applications started by the service, can press the uac prompt.
SecureTech.com.au
SecureTech.com.au
Hi.
I found a refresh problem with the new SC. Now it's needed very often to press the refresh button. In the old SC there are different Poll settings than in the new SC:
Old
Poll On Event Received Only: activated
Low Accuracy: deactivated
New
Poll On Event Received Only: deactivated
Low Accuracy: activated
Can you please restore the old setting? Or as suggestion: Is it possible to create a INI interface for this settings?
Old
New
Luke 'GTH' Filewalker, the one, the only and the real
may the backup be with you - always
Hello.
Maybe I'm overlooking it, but on the download page, where to download "UltraVncSC update 2009"?
I'd like to add it to 2 PCs: Windows 7 (64-bit) and Windows XP (32-bit).
Thanks in advance.
Thanks in advance.
Luke_Filewalker wrote:Another Suggestion: One feature i missed strongly: on a file transfer there should be a requester/splash screen on server side to indicate that a filetransfer is in progress. And then the exact information which files (with path) is transfered would help a lot. I have some users/costumers they said: "what the hell are you doing?". So a requester can help to make a remote session transparently as possible.
agree this point
did you try another vncviewer like 1.0.8.2 ?
remoter:
there not yet sc for vista 64bit/win7 64bit
xp,vista/7 32bit compatible
Thanks for your reply, redge.
Q: Maybe I'm overlooking it, but on the download page, where to download "UltraVncSC update 2009"?
Which of those options to choose? I'd like to use the repeater option, also.
Thanks in advance.
Thanks in advance.
[quote="remoter"where to download "UltraVncSC update 2009"? [/quote]
nothing
only via forum page
Update 27/08/2009
[topic=15865][/topic]
online creator 27/08/2009
nothing
only via forum page
Update 27/08/2009
I guess I'm a bit confused...
1) What is the upload link for? What would I have on my PC to upload?
2) I also didn't see where to download the files on the forum page you referenced.
Not sure what to do yet to get started. Will the repeater feature be included or is that a separate download?
Thanks in advance.
Thanks in advance.
Rudi answered your 2 questions.
just follow the step by step video SC creator
then upload your remoter.zip (example) to this page.
http://www.uvnc.com/pchelpware/sc/creator.html
"UltraVncSC update 2009" on this site http://www.uvnc.com/pchelpware/sc/creator.html
is the same than this? http://support1.uvnc.com/cgi-bin/upload4.pl
Or which do i have to use when i want a working version for Vista and Windows 7?
Thanks for the great program!
