I'm trying to recommend PCHelpWare 1.0 but I'm being blocked due to perception of weak security.
Two simple changes would eliminate all arguments:
1. Change Diffie–Hellman from 512-bit to 2048-bit.
2. Change MD5 to SHA-256 (truncate to 128 bits if needed)
I'm told that using 512-bit DH for key exchange is like using 64-bit symmetric key.
And using "64-bit security" with 256-bit Twofish doesn't make sense if performance was top priority (because using 128-bit Twofish would not have weakened security given other parts are much weaker).
I like PCHelpware much better than SC, etc. so I hope to see these arguments vanish when PCHelpWare 1.1 is released!
Long live PCHelpWare!
PCHelpWare 1.0 Security
Re: PCHelpWare 1.0 Security
char p[512];
char g[256];
char A[256];
char B[256];
char key1[256];
char key2[256];
crcl1.DiffieHellman1out(16,g, p, A);
crcl2.DiffieHellman1in(16,g, p,A, B,key1);
crcl1.DiffieHellman2(B,key2);
Calculating a 512 prime number already take 4 seconds a 1024 prime
is more then 1/2 minutes....
512 == digits
1 char = 8 bit
char g[256];
char A[256];
char B[256];
char key1[256];
char key2[256];
512 == digits
1 char = 8 bit
I agree DH can be slow, and it depends on hardware which gets faster every day. I remember 64-bit encryption being "unthinkable" to break.
Maybe the solution is to add a parameter to let to user adjust depending on their hardware?
For example, this could prevent PcHelpWare from becoming obsolete for many, many years:
1. add parameter to specify DH bit size (512 bits, 768 bits, 1024 bits, etc.)
2. add parameter to specify Hash (MD5 or SHA256)
3. add parameter to specify Cipher (Twofish-256, AES-256) having 2 choices is great just in case a flaw is discovered in one of the ciphers. I like Twofish better, but AES is better known to end-users.
SHA1 is not recommended after year 2010 due to recent discoveries, which is why I suggest SHA256. And MD5 has a bad perception even among people who don't understand hash collisions.
These enhancements might be very simple, assuming a 3rd-party crypto library is used. And it would certainly justify a 1.1 or 2.0 version number
