I have the following error on Windows XP SP3
Connection Failed - invalid Protocol
Posibles causes:
-You´ve forgontten to select a DSMPluggin and the server uses a DSMPluggin
- Viewer and Server are not compatible (they use diferrent RFB Protocol).
I put in CS folder and in the Support folder the same DSMPluggin and the same rc4.key!
Some help please,
2026-09-07: After more 5 000 000 (five million) views on forum for 1.8.x.x development versions...
A new stable version, UltraVNC 1.8.2.9 has been released: viewtopic.php?t=38203
Re: Connection Failed - invalid Protocol
Make sure your are using the compatible DSMPluggin at both end. Version 1.1.x and 1.2.x are not compatible. See the thread [topic=12187]SC with MSRC4Plugin --> "Buffer to big"[/topic] for detail.mloureiro wrote:I put in CS folder and in the Support folder the same DSMPluggin and the same rc4.key!
