I'm trying to set up PCHelpware instead of UltraVNC SC (the latter works fine). I have created simple PCHelpware that does a direct connection to the viewer machine. I have verified network connectivity by telnetting to port 5500 on the viewer. I'm running UltraVNC Viewer in listen mode. But whenever I start the server the viewer program freezes up - no dialog asking if I want to show the session, nothing. When I right click the UltraVNC Viewer icon in the taskbar no menu is shown. All I see on the server is this:
Start
Connecting dierct
<IP>
Connect direct success
Setting up encryption
Waiting for Viewer...
When I stop the server, the viewer suddenly comes back alive again.
I am not using encryption. I have tried with a repeater as well (same problem - the viewer is frozen until server is stopped).
I have tried the server on Windows Server 2003 SP2 machines (DEP disabled), and the viewer on 2003 as well as Vista. I have tried UltraVNC 1.0.2 and 1.0.4 RC14 (simple installations of the viewer only, without video driver).
Any idea what's going on?
Regards,
Oskar
pchelpware server freezes viewer, "Waiting for Viewer"
Re: pchelpware server freezes viewer, "Waiting for View
I suppose you need PCHW viewer.
PCHW is said to be compatible with UVNC only on helphesk.txt level, not in protocol level. It is different product.
That did it! I knew it had to be something as simple as that.poutnik wrote:I suppose you need PCHW viewer.
Now the only problem I have is that I can see the remote computer's screen, but I cannot control it. I'm controlling a Windows Server 2003 SP2 machine from Vista. Any ideas?
In fact, I am not familiar much with Vista and not at all with W2k3 server.
I have just played very little with PCHW recently as SC replacement for remote support for my non-IT friends.
UVNC servers have an option allow/not to allow remote input.
If not allowed, then only looking and advising is possible.
when creating a PCHW custom server, is there such an option ?
Edit: ( Not handy here at work to look at )
Well, even uvnc viewer has option "view only", so check both in
pchw server (e.g. newly created) and viewer.
