Can't get SC to work
ping1
Post by ping1 »
Hello everybody,
I tried to create my own UltraVNC Single Click (SC) executable, but for some reason, it doesn't work for me.
I'm using UltraVNC 1.02 on the client side. If I start UltraVNC in listening mode (with encryption module [MSRC4Plugin_NoReg.dsm, v.1.2.2]), it stays alive until I start the SC exe. SC says "Connection established" and the viewer freezes. The command I used for the viewer was:
vncviewer -listen -dsmplugin MSRC4Plugin_NoReg.dsm
I created the SC exe with the Online compiler. Furthermore I'm sure that my rc4.key files are the same on both sides. I read the Manual and FAQ several times, but I can't spot the mistake....
However, if I start SC without encryption, everything is fine; I'm able to connect, but it doesn't work with encryption. I would really like to use the encrypting feature, since it would be too dangerous to send data unencrypted over the net, to my mind.
Is it possible that the SC Creator uses an outdated encryption module? Could I create a SC exe on my own with an up-to-date encryption module?
Any help would be appreciated :)
Thanks in advance,
ping1
JDaus
Friend of UVNC
Friend of UVNC
Re: Can't get SC to work
Post by JDaus »
caramel has created a nice SC with the addons for vista fix here [topic=11309][/topic] it also has the ability to create the file offline.
try that, you will need to add the dsm (i think) and your key.
hope this helps
SecureTech.com.au
ping1
Post by ping1 »
Sorry, I forgot to mention that I doesn't use Vista. Windows XP is installed on the client and on the server side.
After endless hours of testing I noticed an interesting fact: The connection works, if I use the old MSRC4 plugin v.1.1.8 (can be downloaded here). I created a new SC exe with the old plugin and it works perfectly.
So it seems to me that SC definitely insists on the old version. Any newer version won't work....
Maybe the old SC version is responsible for the weird behaviour?
Nevertheless I'm wondering why other users don't have such problems...
Greets ping1
bevtech
Post by bevtech »
Might need to switch to www.pchelpware.com it is supported by the subtopic of pchelpware
User not developer..;)
