My single biggest request is:
create a mechanism to be able to upgrade somehow the server remotely.
I use UVNC on machines to which I do not have physical access (only once every few months), but would like to update the server every so often with new versions.
This seems to be very complicated at present (i.e. you have to installa SSH or fiddle with the registry to install fastpush). It would be nice to have an option to install a new version remotely on a different directory from the running one and tell the server to restart on the new version at the next reboot for example...
That would simplify life a lot.
After more 1 000 000 (one million) views on forum for 1.5.0.x development versions...
A new stable version, UltraVNC 1.6.0.0 and UltraVNC SC 1.6.0.0 have been released: https://forum.uvnc.com/viewtopic.php?t=38076
Old stable: UltraVNC 1.4.3.6 and UltraVNC SC 1.4.3.6: https://forum.uvnc.com/viewtopic.php?t=37885
Remote upgrade of UVNC server
Re: Remote upgrade of UVNC server
Try upgrade.exe
Place the new version in a subfolder named Upgrade and run upgrade.exe
The next reboot the files are replaced.
Before this existed it was also possible with m$ support tools, with a tool named inuse.exe or if you don't want m$ there is also copylock.exe and many other open file replace tools.
With createinstall you can do a remote upgrade setup in seconds you can set a program termination and disable all the setup dialogs for an automatic installation and you can even have the setup launch the new server at the end of the process. This wouldn't even require restart.Anonymous wrote:Could they just have that built into the setup by now.
Have it install all the required files and wait till reboot to replace the service and register it.
I know other programs are able to do this and all is need is a restart.
I'm looking to upgrade a couple remote servers as well and could use some assistance on the best menthod about doing this. I realize this is a dead topic from a few years ago but I was hoping someone else has used createinstall or knows of an easy way of remotely updating ultraVNC servers.OhMyGoat wrote:With createinstall you can do a remote upgrade setup in seconds you can set a program termination and disable all the setup dialogs for an automatic installation and you can even have the setup launch the new server at the end of the process. This wouldn't even require restart.
Eric
I haven't used createinstall, but I have used a batch file I wrote to upgrade uvnc. You have to create a temp folder and push all the files to it. These are the actual UltraVNC folder files, not the install routine. Put your batch script in the same directory. The batch file should stop the winvnc service (net stop winvnc), copy the new files over the old one (copy using the "no verify prompt" switch), then restart the winvnc service (net start winvnc).ewelin wrote: I'm looking to upgrade a couple remote servers as well and could use some assistance on the best menthod about doing this. I realize this is a dead topic from a few years ago but I was hoping someone else has used createinstall or knows of an easy way of remotely updating ultraVNC servers.
Also, there is a little utility I like to use in my batch files called wait.exe. This will allow you to make the batch file wait before starting another command. I prefer to make the batch file wait a few seconds after stopping a service because it can take Windows a few seconds to do so. Your files will not copy over the old ones if the service isn't stopped yet. You can get wait.exe here: http://www.wcscnet.com/Freeware.htm
Don't forget to thoroughly test your batch file locally before trying it on the remote server!!!!
Hope this helps.
Michael
Michael
