After more 1 000 000 (one million) views on forum for 1.5.0.x development versions...
A new stable version, UltraVNC 1.6.0.0 has been released: https://forum.uvnc.com/viewtopic.php?t=38076
Old stable: UltraVNC 1.4.3.6 and UltraVNC SC 1.4.3.6: https://forum.uvnc.com/viewtopic.php?t=37885
UltraVNC 1.5.0.0-dev - Feedbacks
Feedbacks for UltraVNC 1.5.0.3-dev in this topic.
UltraVNC 1.5.0.3-dev:
- https://www.uvnc.eu/download/1500/UltraVNC_1503-dev.zip
- https://www.uvnc.eu/download/1500/Ultra ... _Setup.exe
UltraVNC 1.5.0.2-dev:
- https://www.uvnc.eu/download/1500/UltraVNC_1502-dev.zip
UltraVNC 1.5.0.1-dev:
- https://uvnc.eu/download/1500/UltraVNC_1501_dev.zip
- https://uvnc.eu/download/1500/UltraVNC_ ... _Setup.exe
- https://uvnc.eu/download/1500/UltraVNCM ... 01_dev.exe
- https://uvnc.eu/download/1500/UltraVNC_ ... v_ipv6.zip
UltraVNC 1.5.0.0-dev:
- https://uvnc.eu/download/1500/UltraVNC_1500-dev.zip
Changelog since the previous stable build:
1.5.0.1-dev
FT, fonts change, I hope this fix the font issue
added version to status window
SC Online: https://uvnc.com/downloads/single-click ... loads.html
UltraViewer -> UltraVNC Manager
1.5.0.0-dev
UltraViewer added (wrapper around the vncviewer)
Directx Reconnect fix
Extra links added
Text/version info fixes
Replaced libs with vcpkg manager for easy maintenance and upgrades
Stack corruption (#185)
1.4.4.0-dev
-code cleanup
-Spellcheck UI
-standardization of UI
-Use CertVerifyCertificateChainPolicy API to verify TLS certificate chain (#144)
-Use Ariel font
-VeNCrypt authentication with TLS encrypted transport (#142)
-WIP: RSA-AES authentication and encryption (#139)
-Fix typo: 'Repetear' -> 'Repeater' (#138)
-fix WinRE 10 detected as unsupported
-change name snapshot, so you can easy sort on date
-use same omnithread for server and viewer
-re-init d3d device in pre-update if invalid (#130)
-SC, added an try/catch to restore UAC if used.
-add scrollbar to properties
-fix: set groups defaults before loading, not after
-SC UAC reset fix
1.5.0.1-dev
1.5.0.0-dev
Extra links added
1.4.4.0-dev
-code cleanup
-Spellcheck UI
-Use Ariel font
-SC UAC reset fix
Re: UltraVNC 1.5.0.0-dev - Feedbacks
Good morning
I have been using your software for a long time and I am completely satisfied with it.
I am ready to test version 1.5, but I use 100% with SC, do you have a test version (winvnc.exe is good for me) ?
Is there a system for making a donation (I try to give some money to all the free software I use)
Good luck for the future
Sincerely
Sincerely
Hi! The new version 1.5.0 does not display the character encoding correctly in the File transfer window.
ver. 1.4.3.6:
ver. 1.4.3.6:
Please add information about the UltraVNC server version to the status window, if possible.
Added version to status window
Please check the UltraVNC Manager, this is a replacement of the old launcher.
It can also be used to have several viewers in a tabbed window, it's a wrapper, it start vncviewer with commandlines and embed it.
Any idea's are welcome
UltraVNC 1.5.0.1-dev/1.5.0.2-dev/1.5.0.3-dev - Feedbacks
Feedbacks for UltraVNC 1.5.0.1-dev in this topic.
1.5.0.1-dev
1.5.0.0-dev
Extra links added
1.4.4.0-dev
-code cleanup
-Spellcheck UI
-Use Ariel font
-SC UAC reset fix
1.5.0.1-dev
1.5.0.0-dev
Extra links added
1.4.4.0-dev
-code cleanup
-Spellcheck UI
-Use Ariel font
-SC UAC reset fix
Re: UltraVNC 1.5.0.1-dev/1.5.0.2-dev/1.5.0.3-dev - Feedbacks
I checked version 1.5.0.1. The problem with character encoding is gone.
The viewer version appeared in the status window, but I asked to add the server version if possible.
I noticed that when the file transfer window is compressed, the scale of the elements changes.
Thanks for the feedback
Will check the remaining issue's
*Server version is not possible, the viewer doesn't know the actual version.
Server and viewer exchange supported options, but they are independent of the version number
This require some extra messages while staying compatible with servers that doesn't support it, not something done in 5 minutes.
This is a nice addon, but not for now.
Yes, I understand that. Thank you so much for your work. Good luck in business!
- 40
I have 1.5.0.0-dev, and lately have been seeing a lot of "authentication rejected" when trying to sign on to a computer. It gets me to the computer, and it provides a password entry box, but then I get that message. Is it maybe something to do with a Windows update? It seems recent.
- 40
Additional information to my above issue:
I downloaded and attempted to install the 1.5.0.1-dev version. It complained about 4 running instances of VNC Viewer. I quit the installer and tried again, same result. I then tried running as Administrator, same result. I then went into Windows Task Manager, and saw that there were indeed 4 instances of VNC Viewer running. These were running in the background I guess, since there were no open windows or other indication these were running. After I killed those 4 processes, it was able to install OK.
Verdict?
Verdict?
There are two builds after the 1.5.0.1-dev.
Of course, please use 1.5.0.3-dev.
1.5.0.2-dev:
1.5.0.3-dev:
Can you do feedbacks? Thanks.
1.5.0.2-dev:
1.5.0.3-dev:
- 40
Where are the descriptions? It would be helpful to put them right along with the downloads. Unless I just missed it somehow.
I also noticed some issue. Mainly I faced issues with the secure plugin in UltraVNC 64-bit installer. It includes SecureVNCPlugin.dsm with a size of bout 1.3MB from 17.11.2019. It might not even be 64-bit. Weirdly the 32-bit installer includes SecureVNCPlugin.dsm which is sized 2.2MB and build on 19.09.2023.
In Previous 1.4.x builds the 64-bit edition included SecureVNCPlugin64-.dsm with a size of about 5MB.
No surprise then that the plugin does not work and cannot be loaded by neither the Client nor the Server.
Note: If 1.5.x versions are installed on top of an existing 1.4.x version the SecureVNCPlugin64.dsm is not removed. So you might end up with a partially working version. In My case the Client was able to load SecurteVNCPlugin64.dsm (still there from 1.4.x installation) but could not connect to any server as it disconnected due to missing (and required) encryption on server side which failed to load the broken SecureVNCPlugin.dsm (Server was a fresh install).
The way to recover such broken server installations is to allow connections to unencrypted servers in client options.
However I think the installers need a fix to include the right plugin.
Thanks for the feedback, i will check the plugins
Starting from some version 1.4.x and up to the current 1.5.0.3, when using SecureVNCPlugin.dsm, the encryption algorithm is displayed incorrectly in the info window
should be fix now, box was to small ( upcoming 1.5.0.4)
Please use the latest UltraVNC development release:
- https://forum.uvnc.com/viewtopic.php?t=38037
